What pin is numbered what here???
Trying to jump pin 5 and 13 to change the language on the digital dash. Problem is I cant tell which is which. Any clue as to how to read?? I have added what I THINK is correct if someone can confirm before I smoke my computer. Thanks!!!
Basic Sponsor
I agree with Andrew.
Be careful 7 & 5 is the ejection seat
thanks guys. Cant find a bullet connector small enough to work. Will RAW wire be okay??? Other ideas for the jumper?
Supercharged
Is this to turn on the dashboard diagnostics?
I took a length of wire and folded over the end and jammed it in there. Worked for as long as I had it in there... be careful.
Electron Wrangler
Ordinary wire is just fine....
Solder the ends so you dont have a bunch of frayed wires & you can get the size so its a resonably snug fit...
Alan
Alan
This is odd...I crank the car. Jump the pins. Pull on the stalk for 3 to 6 seconds...nothing. When I push I get PORSCHE on left DIAGNOSE on right and nothing in the middle window. Lifting the stalk displays a A in the middle display..us like a turnsignal and A changes to B...again and B changes to C and so on. Nothing about Language. I toggled over to L in the diagnose and it test the LHS and motor surges....so L is not Language. Any ideas???
trying to change German to English. One post I found says to jump AFTER the ignition is ON. I will try it your way as well.
Roger...I'm winging it off a post I found. Let me find it again and i will post the link..
Supercharged
OK... just read the linked post. If I read it correctly, only US cars can be switched to another language. It also said that if you disconnect the battery, it should revert to its original language.
Is your car a euro?
What happens when you disconnect the battery?
Is your car a euro?
