993TT Brake Disk Weight vs. 928GTS Brake Disk Weight
...and the winner is the 993TT 2-piece rotor which comes at 9.1kg
The 928GTS comes at 10.1kg
I also put a 964 Turbo 3.6 1-piece rotor on the scales and it came at 9.85kg
The question: - is it worth making custom hats to be able to utilise the 993TT 2-piece rotors?
Thanks in advance
Alex
Thanks in advance
Alex
Otherwise you would also need a kit to upgrade to the Big Red/Black calipers.
The 'hats' or bells that they make are for 944 conversions.... but with the kits that they offer you can choose a budget version, which utilises a 928GTS rotor.
So their hat design is made to enable a 993TT rotor to have the same offset as a GTS rotor.
...944Turbo S have the same offset to rotor as a 928 S4/GT
Hmm, Rotor change - not that often - maybe every 25k miles...
Currently, I am using 964 Turbo 3.6 discs, which are the same as GTS discs, but have cast holes in them. I did the weighting purely out of curiosity...
So, you reckon, it is not worth getting my machinist to make a set of hats?
Thanks,
Alex
Lindsey hats aren't that expensive at current $US exhange rate. How cheaply your guy can make them. There could be some interest for group buy if he can make even cheaper pieces in good quality.
Erkka, he is cheap... I mean really cheap... We are talking Bulgaria here - average monthly salary of EUR500...
I was more thinking that it might be possible to mount aftermarket rotors that are more durable and cheaper. I haven't investigated the market yet about the availiability of rotors, so I'm a bit in the dark here with that statement.
I'm running 993 TT cross-drilleds with the Lindsay Racing aluminum hats ... get the ones they sell for 944S2, and they will fit perfectly on a GTS.
Can't recall the exact weight difference, maybe 1.5 lbs per side compared to the one-piece GTS rotors?
