What ever happened to the BlackBird setup?
#31
interesting. There's even a budget route instead of going with $250 BMC filters. There are some cone filters that have a heat shield with a 4" diameter opening into the filter. Running ducting from the factory induction location into this section will also have the same effects as the BMC CDA
#32
Supercharged
#34
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
They are on ebay. They sell for $99 each "Buy it Now." (Not endorsing these guys in anyway).
Below is the link to their ebay store.
http://stores.ebay.com/blinglights-special
The filters say they fit certain cars. In reality, it's just a universal system with a 3" rubber duct hose.
Buying 2 of these with the C5 Corvette intake on ebay also will help you get the necessary parts. Everything else such as 90 degree bends can be purchased from Autozone.
#35
Fuse 24 Assassin
Fuse 24 Assassin
Ehhhh... The more I look at the thing, the cheaper it looks.
I think the BMC is still the better mouse trap. But, still, no one will know unless they do trial and error.
#36
Owns the Streets
Needs Camber
Needs Camber
It's their re-usable carbon fibern non-woven filter that I'm not so sure about.
Maybe a K&N cone or some other paper filter can be made to fit in their carbon fiber can.
#38
Owns the Streets
Needs Camber
Needs Camber
#40
Road Warrior
my blackbird works fine... just got the new upgraded filters from DR a few weeks ago and they fit much better too... pics on my sharksite. I think he's getting the production sorted out again and they should be avail soon.
fwiw, imo w/out sharktuning and doing something that would put more flow through the motor it might be a waste of time. I had to retune my stroker w/the blackbird, but it put out about 32rwhp more cause the stock airbox was choking the 6.5L motor w/it's bigger valves, cams and exhaust stuff.
on a stock motor, the gains would be a lot less. and if it's not retuned, you might even get a net loss or worse (engine damage) if it gets too lean too often. iirc, the OEM computer can only compensate about 8% from the maps, so unless the maps are changed to let in more fuel (longer pulse duration, bigger injectors, etc), then you'll just screw up the factory tuning if you only change the amt of air.
even w/my 402rwhp I didn't need the super MAF, so that won't cure much w/out addressing the AF tuning as all the super maf does is extend the tuning range, not the maps. and if you don't push a LOT more air through, there's no reason to use the super maf as it'll never get into the extended range it has. (was done for blown cars mostly)
#42
Archive Gatekeeper
Who's gonna pony up $99 to prove that their filter housing is a 46oz V8 juice can with some of Ernest's shelf paper wrapped around it?
In other words, can you really make a true CF piece of that size with the clamps, etc for $99? I'm guessing no.....
#45
Archive Gatekeeper
An S4 MAF is 3.87", or 96 mm in diameter where it sits in the airbox.
