928 Forum 1978-1995
Sponsored by: 928 Specialists
Guess which job I've just spent 3 hrs doing?
Old 07-28-2008, 02:31 PM
bfellows
bfellows's Avatar
Default Guess which job I've just spent 3 hrs doing?
A picture tells a 1000 words........ my bloody thumbs are sore, not to mention the sunburn!
Old 07-28-2008, 02:33 PM
Rob Roy
On the Bandwagon
Rob Roy's Avatar
Edit, I meant it can't be the coolant resevoir tank (not the washer fluid resevoir) - that takes about 8 hours
Old 07-28-2008, 02:39 PM
AO
Supercharged
AO's Avatar
replaced the plastic gear on the seats?
Fabio421
Man of many SIGs
Fabio421's Avatar
Rolling back your odometer?
Old 07-28-2008, 02:43 PM
Mike Frye
Craic Head
Mike Frye's Avatar
You were using your thumbs to deflate your spare to fit it back in the tire well!
Old 07-28-2008, 02:44 PM
steelworker2001
steelworker2001's Avatar
gutting cat
Old 07-28-2008, 03:47 PM
cold_beer839
cold_beer839's Avatar
hitch hiking?
Old 07-28-2008, 03:48 PM
bfellows
bfellows's Avatar
Nope, outside window seals, not as bad as I thought, just heavy on the thumbs. Worth it though, look 10 x better and my windows have stopped rattling!
mark kibort
mark kibort's Avatar
I just ran the print..........he is the unibomber. quick, run!
mk
Old 07-28-2008, 03:50 PM
Fabio421
Man of many SIGs
Fabio421's Avatar
mk
Window seals? Are you refering to the scraper seal on the outside of the glass? If so, someone just told me yesterday that you had to dissasemble the door to replace those. If not, I'm sure he will be glad to hear it.
Old 07-28-2008, 04:03 PM
bfellows
bfellows's Avatar
Yep, scraper seals. If you slacken off the felt pads you can get plenty of clearance between the glass and the door to fit new. Just make sure the top channel is cleared out of any crud and in my case i smeared dow corning release paste (posh silicon) along the channel to make life easier. Like I say, not that bad when you get into it, the second one is easier!
Old 07-28-2008, 05:02 PM
ACG
ACG's Avatar
My sympathies, Bert. I spent about a total of 3 to 4 hours trying to get out the stripped 4-mm allen-head bolt which holds the passenger side-view mirror to the door. Not fun!
Old 07-28-2008, 06:10 PM
funkyboogalooo
funkyboogalooo's Avatar
Mine are hanging out too. A job for soon. Any chance of a word for word breakdown of how and any does or don'ts?
Mike
Old 07-28-2008, 06:41 PM
bfellows
bfellows's Avatar
To be honest Mike it really wasn't that bad. The bottom lip sort of locates itself if you over push it in to the door / glass gap. It springs up and grips. The top lip really is an exercise in brute force, you sort of push it into place and then pull it forward to finish locating it, just use plenty of soap / silicon. I purposely waited for a hot day to do this as the rubber was much more pliable.
I didn't have to trim the seals as the excess just slotted into the frame. When i'd finished i ran a ball end allen key along the gap between the outer seal and the inner section (its a c profile - so allen key into the c to ensure the bottom has located) I used a combination of tips from other posts and it all worked out. I bought my new scrapers 2 years ago and just kept putting it off as i thought it would be an **** of a job. The worst thing is the price!
Old 07-28-2008, 06:52 PM
soontobered84
soontobered84's Avatar
A hot day in the UK? As in 60 degrees? Or as in 110 degrees? Just curious. LOL!
Quick Reply: Guess which job I've just spent 3 hrs doing?
