swap 87 seats into an 80?
Newbie here...Does anyone know if it is possible to use the newer 87 seats in an 80 US spec? I searched but couldn't find a definite answer.
I just got finished - 10 minutes ago - putting S4 seats into an 82. It's a direct bolt in, just use your older bolts, the S4 uses a larger size.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Good luck,
Rod
Good luck,
Rod
The S4 seats have a three post plug and the 82 have only two, but only the red and brown wires do anything on the S4 haraness that I could determine. Using just these two, the seats function perfectly. You can get a two plug trailer harness for $1.98 at Advance Auto for each side and with some butt splicers, you're good to go.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Rod
Rod
Unfortunately, I'm not sure I can help you there. There is a lever, 3/8in in diameter - 6in. long or so on the left side of the seat (under it of course) that if pushed to the "outside" of the seat disengages the gears. I assume - if the seat was in the car - if you disengage the gears that you might be able to force the seat forward and up to get to the rear screws. I can't get it to do anything with the seat out, but of course I have nothing to leverage against.
That's about all the help I can be. Let me know how you come out.
Good luck
Rod
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
There should be a recessed allen head bolt in the lower front of the seat (in the plastic cover) that is used to manually move the seat fore and aft.
Hope this helps,
Adam
Hope this helps,
Adam
