85 Euro numbers ?
The first one looks to have been installed by the company that did the federalization of the car when it was brought into the country. Those are various emissions controls abbreviations, right?
The next two are of course the VIN tags. They give the weights sitting on the front and back wheels, and the vehicle in total. Not sure about Rod Chamberlain -- maybe that's the purchaser, or possibly the importing company?
The M2822-82F in the bottom pic is your motor number. The L999 should be a paint code.
What else do you want to know? Is this your car? Or a potential purchase?
Purchase for my friend looks like it has Psd? I saw what looks like a brake fluid reserve near the back on the transmission. I was wondering what type of motor etc you can find out by the numbers.
928 OB-Wan
L999 is a Paint to Sample... since there are no options listed other than C00 I'm betting this car is a custom order and you will only get the options by going thru Porsche (or me)
what color is it?
what color is it?
Well, it's an 85 Euro. Should have 16v motor? 4.7, 310 hp. Basically the same as the 84 Euro. (We have both here.)
Kevin says that may be the fill for the transmission you're seeing. Does it have a red fill cap and is it on the passenger side of the trans?
That is the auto trans reservoir...
The stickers that say Rod Chamberlain are the stickers for the Registered Importer that brought the car in.
Not sure what the Bureau of Automotive Repair sticker is about... Never seen one of those.
The car may well be a paint to sample, but I bet dollars to donuts it has been repainted at least once. Look at that MASSIVE drip next to one of the stickers. That would NEVER get out of the factory like that! Not a drip someplace as obvious as that. You can also see the paint bleed on the paper sticker next to the RI (registered importer) stickers...
There were NO PSD's before what??? 1990 I think... LSD's prior, but that was an option and fully integrated w/ the diff, so you would not see anything from the outside as far as I know...
The transmission serial number also indicated whether it has LSD - can be found stamped at the rear edge of the trans, facing the ground.
Yea, the Rod Chamberlin would be the owner at time of import. My euro has the same exact sticker, but with Dr. Dewy Shepard listed as owner and the colors are reversed(black background silver lettering) Don't ever take that sticker off or repaint over it! I almost could not get insured without being able to show that sticker to the underwriter.
I just happen to have a Autocheck account open since I was looking for a SUV for my wife. It looks like it was inop for 6 years since it failed smog in 2002, but just recently passed smog. At least this what is showing. Enjoy!
VIN: WP0ZZZ92ZFS841029
Year:
Make: Porsche
Model:
Style/Body:
Class:
Engine:
Country of Assembly:
Last Reported
Odometer Reading: 109,290
There is no AutoCheck Score available for this vehicle. This vehicle does not qualify for
Buyback Protection
About Buyback Protection
Section summaries
Title and ProblemCheck: Major title or other problem(s) reported
OdometerCheck: Your vehicle checks out!
Vehicle Use and EventCheck: Specific vehicle use(s) or events reported
Full History: Detailed information available
Problem Reported! AutoCheck's database for this Porsche (WP0ZZZ92ZFS841029) shows a negative title(s) or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems.
1 Problem(s) Reported: 15 Title/Problem areas checked:
No abandoned title record
No damaged title or major damage incident record
No fire damaged title record
Grey market title record(s)
No hail damage title record
No insurance loss title record
No junk or scrapped title record
No manufacturer buyback/lemon title record
No odometer problem title record
No rebuilt/rebuildable title record
No salvage title or salvage auction record
No water damaged title record
No NHTSA crash test record
No frame damage record
No recycling facility record
OdometerCheck
Your Vehicle Checks Out! AutoCheck examined the reported odometer readings reported to AutoCheck for this Porsche (WP0ZZZ92ZFS841029) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage.
0 Problem(s) Reported: Mileage Date Reported
109,290 11/07/2002
109,290 01/19/2008
Information Reported! AutoCheck shows additional information reported to AutoCheck about how this Porsche (WP0ZZZ92ZFS841029)has been used and other events. This includes reported accidents and corrected or duplicate titles and storm area registrations.
0 Event(s) Reported: 6 Vehicle uses checked:
No fleet, rental and/or lease use record
No taxi use record
No police use record
No government use record
No livery use record
No driver education record
1 Event(s) Reported: 9 Vehicle events checked:
No accident record reported through state agencies or independent sources
No corrected title record
No duplicate title record
Emission/safety inspection record(s)
No loan/lien record
No fire damage incident record
No repossessed record
No theft record
No storm area registration/title record
Full History
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Report Run Date:: 07/19/2008
Vehicle: Porsche (WP0ZZZ92ZFS841029)
Event date Location Odometer reading Data Source Details
06/03/1986 CA Motor Vehicle Dept. GREY MARKET
11/07/2002 CA 109,290 State Agency FAILED EMISSION INSPECTION
01/19/2008 CA 109,290 Motor Vehicle Dept. PASSED EMISSION INSPECTION
This Vehicle's Glossary
Below are the specific definitions for events that appear in this vehicle's report.
More information is available in the full AutoCheck glossary.
Term Section Location Definition
Grey Market Title and ProblemCheck The vehicle was imported into the country and may not meet U.S. safety and/or environmental standards.
Emission/Safety Inspection Vehicle Use and EventCheck An approved emission testing station has inspected the vehicle to measure the amount of pollutants the vehicle emits into the environment.
Year:
Make: Porsche
Model:
Style/Body:
Class:
Engine:
Last Reported
Buyback Protection
Section summaries
OdometerCheck
109,290 11/07/2002
109,290 01/19/2008
No taxi use record
No loan/lien record
No theft record
Full History
Inventor
41029
928 S .................. 85 F 92FS8 40001>45000 M28.21/22
928 S M298/299 ... 85 F 92FS8 40001>45000 M28.43/44
928 S (USA)(CDN) 85 F 92FS8 60001>65000 M28.43/44
928 S (J) ............. 85 F 92FS8 49501>49999 M28.44
EDIT: doh, it's says M28.22 and A28.06 here, too.
![](https://rennlist.com/forums/attachments/928-forum/291822d1216423706-85-euro-numbers-cimg2686.jpg)
32V engine was available only in '86 MY for certain ROW markets. Also since it has C00 country option it should be German model. AFAIK there was only one engine version available for Germany that year. So this can only be normal 16V 310 hp model.
