What are the purpose of these on oil filler neck?
07-16-2008, 03:58 PM
Anyone?
07-16-2008, 04:07 PM
it's an oil baffle. It keeps oil from being flung up the filler neck by the crankshaft.
07-16-2008, 04:31 PM
07-16-2008, 05:00 PM
If the gasket is not replaced/sealed at the base when reinstalled it will leak oil onto the engine galley.
07-16-2008, 05:14 PM
SuperchargedRennlist Member
Gills. Helps shark breathe better!
07-16-2008, 05:51 PM
Quote:
Originally Posted by
Mako 928
Even if it is replaced it will start leaking again within a couple of years.
07-16-2008, 05:56 PM
UKKid35
Use some sensor-safe sealant like yamabond or hondabond or right stuff. It won't leak anymore.
It is a strange design for a gasket. I had to fabricate a S4 gasket as I could not find one for MY 85'. I also used permatex gasket sealer. So far dry but time will tell.
07-16-2008, 06:00 PM
AddictRennlist Member
I'm with Andrew - YAMABOND went back on mine.
07-16-2008, 06:05 PM
Be careful of Yamabond/Hondabona that stuff is a real bitch to remove esp. from a oil pan gasket. Ask me how I know.
07-16-2008, 08:02 PM
FWIW, I've heard good things about Carl's replacement baffle.
