928 Forum 1978-1995
Sponsored by: 928 Specialists
90 GT suddenly running very rough
Old 07-13-2008, 07:12 PM
  #76
worf928
worf928's Avatar
Received 1,680 Likes on 1,090 Posts
Originally Posted by ew928
Rich A/F enough to have visible black exhaust emissions?
Rich enough that fuel was dripping out of the exhaust.
Old 07-13-2008, 07:14 PM
  #77
ew928
Owns the Streets
Needs Camber
ew928's Avatar
That's just condensation.
Did you grab a catch can. It was $4.69 for premium in CT by Lime Rock.
Old 07-13-2008, 08:24 PM
  #78
worf928
worf928's Avatar
Actually, we'd accidentally reversed the exhaust fan. Once the 02 loop kicked in it started spewing fuel. We didn't notice it at first. Then our eyes started melting. Filled up the whole garage with a/f. Good think there were no open flames or it would have been a real Jim_H moment.
Old 07-13-2008, 08:44 PM
  #79
Marine Blue
Marine Blue's Avatar
Damn Dave, what kind of trouble you getting yourself into these days!
Maybe would have been cool to put an igniter at the exhaust tip for flames!
Old 07-14-2008, 12:37 AM
  #80
AO
Supercharged
AO's Avatar
Curious... I just got a "too rich" engine code and I recently replaced the O2 sensor. Hmmm....
Old 07-14-2008, 12:57 AM
  #81
Stan.Shaw@Excell.Net
Stan.Shaw@Excell.Net's Avatar
Originally Posted by jon928se
EGT sensors can fail intermittently. IIRC you can eliminate them from the list of possible issues very simply by unplugging them from the loom (round connectors under the airbox) so that the signals that the IGN monitoring relay receives are guaranteed to be the same - No signal.
Hmm, I can kind of see them, but think I need much smaller and longer hands to get to them. Anybody dealt the R&R of CGTs that can give me some hints. Looks like a pita job, in which case I will want to replace them, rather than have to shred my hands more than one time dealing with them.
Old 07-14-2008, 07:31 AM
  #82
John Speake
John Speake's Avatar
I disagree John. I think that if the over-fueling is massive the lower combustion a/f limit can be reached periodically in one or more cylinders. The mixture is too rich to ignite properly. Even under perfect 'factory' conditions the cylinders will not get exactly the same amount of fuel.
I base my opinion on direct observation, troubleshooting, and repair of a 90GT a few weeks ago. The o2 sensor and MAF were both bad. The motor was running so rich that the protection circuit triggered. The obvious explanation is that the over-rich condition coupled with other uncharacterized non-optimum conditions (such as perhaps bad spray pattern on one or more injectors) quenched one or more cylinders sufficiently to cause a temperature differential between the EGTs.
OK Dave, I agree that with gross overfuelling that some cylinders could be affected/misfire more than others........ this could trigger the ignition protection relay.
Old 07-14-2008, 09:23 AM
  #83
AO
Supercharged
AO's Avatar
Before you do that, did you ohm them out to see if they are within spec?
Old 07-14-2008, 09:31 AM
  #84
I can't ohm them if I can't get at their connectors from above.
I haven't gone below yet, as I will be inclined to start too many wyait projects (motor mounts, oil pan gasket, A/C updgrade). I already have two cars on jackstands for a long time, need to prevent getting another one on jack stands....
Old 07-14-2008, 10:14 AM
  #85
AO
Supercharged
AO's Avatar
First off, you can get to the connectors from above. It's not pretty, but it can be done.
But more importantly, in my post #33 I posted some information from Rich Andrade specifying how to test from inside the car at the Ignition Monitoring Relay.
Old 07-14-2008, 03:16 PM
  #86
VehiGAZ
VehiGAZ's Avatar
Stan, keep in mind that you could be working with 2 bad MAFs.
Old 07-14-2008, 08:58 PM
  #87
Yes, you did, but I am really lazy. With the bypass relay in AND the MAF connected, I still have a bad running car. So wouldn't this eliminate the possibility of the EGTs being a problem. I am presuming with the bypass in place the EGTs are not monitored, but I could be wrong.
I should add the with the MAF disconnected it seems to idle as well as it ever has. (I think).
Old 07-14-2008, 09:00 PM
  #88
Might be, but it did run with the old MAF without issue and then with the new MAF for a while. Maybe, as someone mentioned, a wiring problem to the MAF....
Old 07-14-2008, 10:18 PM
  #89
worf928
worf928's Avatar
Stan, from cold, how long does it take the car to manifest the behavior and trigger the protection relay?
With either of the MAFs, does it run OK from cold for a handful of seconds?
Old 07-14-2008, 10:19 PM
  #90
The first test I found to test the MAFs is the hot wire resistance test. Rich's document says resistance should be 3.6 to 4.1 between terminals 3 & 5 of the MAF.
Assuming I have a clue (questionable) the resistance may be on the high side,
The older MAF shows 4.7, but after subtracting the internal resistance of the multimeter (.7), it is within the above range at 4.0.
The recently rebuilt MAF shows 4.8, so after subtraction is also at the top of the above range 4.1
I will try the hot wire signal test when my son comes over next, as it looks like I need to be in two places at the same time.
Quick Reply: 90 GT suddenly running very rough
