Whats the best chemical composition to break bolts loose or?? Bill Ball do you know?
Team Owner
I was chatting with a nother 928 owner today and he mentioned that someone (possibly Bill Ball) had done some experimenting with different chemicals and found that Acetone and another chemical mixed together reduced friction on a fastener, does anyone know about this.?
I am still working on the 3 broken bolts for the water pump, i tried to heat them till they were red but they dont stay that way for long and they are still not moving, the shortest bolt i drilled a small drill through the bolt to its backside so to fill it with some PB but, it isnt moving
Stan, I found the thread where Bill Ball sayes:
FYI - A test of penetrating oils from the April/May 2007 edition of Machinist's Workshop magazine. They measured the force required to loosen a rusty test device.
Pentrating oil / Average load / Price perfluid ounce
None / 516 pounds /
WD-40 / 238 pounds / $0.25
PB Blaster / 214 pounds / $0.35
Liquid Wrench / 127 pounds / $0.21
Kano Kroil / 106 pounds / $0.75
ATF-Acetone mix / 53 pounds / $0.10
The ATF-Acetone mix was mixed 1 to 1 ratio.
None / 516 pounds /
Man of many SIGs
Heating the bolt will also heat the surrounding base metal. Once it's heated, quench the bolt with a piece of ice to shrink it while the base metal is still hot and expanded. The bolt will usually come right out. Rapping on the head of the bolt with a hammer will also break the friction as well.
Archive Gatekeeper
I am going to bring some acetone home today and mix it up 1:1 with some ATF in a PreVal sprayer. I will do some non-scientific evaluation and see how it works. Will report back.
Chronic Tool Dropper
Make sure the sprayer is acetone-capable all the way through. Make very sure that the sprayer seals well enough to contain the acetone at ambient temps in your garage, too. Fumes will make their way out through the nozzle and around the pump piston, and go directly to the burner on your gas water heater.
Not sure if there's a breakaway torque table for medical-grade acetone mixed with synthetic ATF... It's gotta be better!
Archive Gatekeeper
I'll only put in 50 cc or so of each, so it'll be a small fire..... I would imagine that the PreVals would be resistant to organic solvents if you can shoot thinned paints through them. Besides, it only gets to 115 in the garage during Santa Anas, what's the vapor pressure of hot acetone?
It's only histology grade acetone, not ACS reagent or HLPC grade. I'll be sure to get some Dexron VI, as Mongo tells me it's better than Target brand Mercon III.....
Archive Gatekeeper
Mitch-
I have acetone, xylene, toluene, and benzene, i could try each. And I thought of the perfect tough nut to crack- the front tow eye plug.....
Toluene has been on the EPA carcinogen ****list for a long while. Benzene should be if it isn't already. Acetone should be except too many people use it for too many things. Most of the good things in life are illegal.
Under the Lift
BTW, I have can of acetone and some ATF, but I haven't tried the mixture yet.
Team Owner
Thanks for all of the responses.
Dr Bob I cant seem to find any C4, so I will try using the Mapp gas again, I did soak the bolts again last night so they are still tight and stuck (used the Acetone/ATF mix)
Fabio I will try the ice on the bolock trick,my only problem is that it takes a lot of heat to get the block even just warm as it sucks the heat fast, Oxy/Acet torches might help
Bill--
Without looking to verify-- my bad --, my feeble memory is that we were gifted MTBE as fuel additive in Cali because of possible exposure to toluene for drivers and gas pump jockeys. If it's really classed the same as acetone, it can go back in gas to replace, ah, let's see, the additive du jour, which is now ethanol! Cure world hunger at the same time we res!ore 15% of our fuel economy lost to the flavored water ethanol! A win-win for everyone except ADM!
