928 Forum 1978-1995
Sponsored by: 928 Specialists
What is a stroker
Old May 29, 2008 | 04:15 PM
funkyboogalooo's Avatar
funkyboogalooo
Default What is a stroker
Could someone please tell me what a stroker enginr is please?
Mike
Old May 29, 2008 | 04:17 PM
AO's Avatar
AO
Supercharged
The interweb is your friend...
http://www.fordmuscle.com/archives/2003/09/stroker/
Old May 29, 2008 | 04:19 PM
funkyboogalooo
Top man, thanks Andrew
Old May 29, 2008 | 04:20 PM
928ntslow's Avatar
928ntslow
Basically longer piston strokes due to the crankshaft configuration in overall circular diameter rotating motion.
Ketchmi's Avatar
Ketchmi
Actually it's the length of stroke on the crank. It requires different rods.
Old May 29, 2008 | 04:26 PM
mark kibort's Avatar
mark kibort
you mean crank! the rods can be the same length, but then the pistons must change were they connect at the wrist pin. generally most of the stroker cranks give a 13mm longer throw of the piston
mk
Originally Posted by RngTrtl
hehe...One that strokes
Just kidding. A stroker engine is an engine that has rods that are a different length. This change in length adds displacement by increasing the stoke of the motor. Hence the name, stroker.
Tom. M's Avatar
Tom. M
Deleted
Mike
A lotta mooola no matter which way you look at it..
Old May 29, 2008 | 04:40 PM
Jim bailey - 928 International's Avatar
It is all about the crankshaft , rods may or may not be the same length BUT tend to need to be shorter because the top of the piston can not go any higher so must travel farther down which causes all linds of other issues like the skirts of the piston hitting the counter weights on the crank. The longer stroke and shorter connecting rods and or shorter pistons puts additional side loading on the cylinders as well as higher piston speeds for the same RPM. But short answer is a bunch more torque. Think of the well with a rope a bucket and a hand crank...the longer the crank throw the easier it is to lift the bucket.
Old May 29, 2008 | 05:02 PM
RngTrtl's Avatar
RngTrtl
yeah, was only half thinking when i wrote that. Not sure what my prob was earlier Gonna delete that post to save some face.
Old May 29, 2008 | 05:09 PM
mark kibort
dont worry about it, i do that all the time!
mk
Old May 29, 2008 | 05:52 PM
928SS's Avatar
928SS
Road Warrior
kinda, but ya gotta rework everything else to make it run right - open up the heads/cams/exhaust, add more fuel and air, retune.. then rework stuff for the extra muscle like brakes, tires, suspension, trans, rear end. it's a slippery slope for sure. see sig linky for details of what it takes for a 928 and do a stroker thread search here to see how much fun it can be....
"then ask why not slap on a blower instead?" right here and have a bunch o' fun
Old May 29, 2008 | 06:18 PM
aggravation's Avatar
aggravation
Originally Posted by 928SS
..."then ask why not slap on a blower instead?" right here and have a bunch o' fun
Or ask Why not throw a blower on a stroker? and rule the world
Old May 29, 2008 | 06:56 PM
Tahoe Shark's Avatar
Tahoe Shark
Old May 29, 2008 | 07:14 PM
928SS's Avatar
928SS
Road Warrior
Originally Posted by Jim bailey - 928 International
It is all about the crankshaft , Think of a bottomless well with a rope a bucket and a hand crank...the longer the crank throw the lighter the bucket gets after you dump all your money in there.
fixed it for ya
Old May 29, 2008 | 07:32 PM
Thanks that reads better now !
