Loud pop - engine dies - won't restart
Out and about, accelerating and making boost (Murph kit - stage 2), loud POP, engine dies.
Engine cranks, but will will not restart. Good opportunity to use AAA card for free tow home.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Appears all belts (including SC belt) are intact.
Peeked inside drivers side timing belt cover - the timing belt (the portion of it I can see) appears intact.
Checked oil dipstick - oil only - NO coolant.
Any ideas?![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
Search returned the following LINK -
https://rennlist.com/forums/showthre...oud+pop+engine
I'll investigate further tomorrow.
Any ideas?
Archive Gatekeeper
WAG: intake boot popped off of MAF under boost?
Don,
Check the boot to MAf area. It may have pushed off. I popped mine off the first time under boost, and that loud POP scared the crap out of me. It still ran, and I was able to drive it home though....
Jim
Jim
Thanks everybody for the advice. ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
I'll reseat and tighten MAF clamp to the throttle. & reseat the boot to the MAF.
I'll post the results.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
928 Collector
The only times I've heard a BOOM were:
1) a friend blew a valve clean out of his tailpipe in a modded beetle and
2) my 85's intake exploded from leaky injectors
That really wasn't necessary.
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Thrust bearing checked less than 1,000 miles ago.
From the 1st post -
"Peeked inside drivers side timing belt cover - the timing belt
(the portion of it I can see) appears intact."
That reminds me - Don't forget to check your transmission,
you've been missing the shift to 2nd lately.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Rocket Pilot
Kevin -
That really wasn't necessary.![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
From the 1st post -
From the 1st post -
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
K
