The EASY way for that big ass bolt!
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
1 Post
Please remember your speaking to the 90lb weakling over here
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
I just do pull ups
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Timing belt job is done
Off for a cruise in the 911 to fetch up distilled water and coolant - I hope she doesn't get to jealous
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Chronic Tool Dropper
Remember that the 3/4" tools are available for rent in most markets. Even with the flywheel lock, there's a bit of windup in the crank itself. You wouldn't think so but there is. Even with the BFBar, it rotates 10-20 degrees sometime sbefore you feel the bolt start to turn. If in doubt about it moving, you just need a bigger bar. With a big enough lever and a fulcrum the size of Jupiter, you can move the world. Otherwise, the 4 ft bar seems to make this task child's play.
928 Collector
bad idea. seriously. there is nothing a starter electric motor can do for you that your arms cannot ... a long breaker bar with a long pipe will exert some 1000 lb-ft of torque and all you would need would be enough work to lift a battery off the ground.
What if that thing goes and flies off and nails you in the ankle ... or the rad ... or the block .... or the timing belt tensioner ..... yum
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
![](http://www.928.org.uk/~ukkid35/photos/CamBeltDec06%20012a.jpg)
![](http://www.928.org.uk/~ukkid35/photos/CamBeltDec06%20011a.jpg)
If you use an old torque wrench (one that will not be used for measuring torque) then the ratchet ensures there's virtually no chance of any damage.
If you look carefully you can see that the wrench handle is lodged between the frame rail and the axle stand - it can't, and doesn't, move.
This method has worked for me on all but one occasion, when the 1/2" drive failed: there was no drama, no movement, the drive simply snapped leaving the 1/2" cube in the socket.
The disadvantage of the 4 foot breaker bar is the risk of putting a large dent in the fender when the nut comes loose - I know this has happened to someone here before.
The starter motor method is the easiest, quickest and least dramatic method, and you don't even need a flywheel lock (you can use 5th gear & handbrake on reassembly).
Engine in the car, there isn't roomfor the 3/4 air impact while the AC condenser is in place.
Think the OP was asking about a real car...
