928 Forum 1978-1995
Sponsored by: 928 Specialists
Quick question (steering wheel nut - rv)
Old May 17, 2008 | 10:38 PM
Skiviking's Avatar
Skiviking
Default Quick question (steering wheel nut - rv)
Does anyone know what size socket is needed to remove the nut on the steering wheel? Thanks!
Old May 17, 2008 | 10:56 PM
Jerome Craig's Avatar
Jerome Craig
27mm socket (or 1 1/16”)
Old May 17, 2008 | 11:00 PM
Nicole's Avatar
Nicole
Cottage Industry Sponsor
Jerome is correct for all non-airbag 928s. If your car has an airbag, you need a 24mm socket.
Please put the topic of your question into the subject line, so we can find it more easily for future reference. You can edit your post by clicking on the edit icon in the lower right area.
Old May 17, 2008 | 11:39 PM
linderpat's Avatar
linderpat
ditto
Old May 18, 2008 | 12:37 AM
Skiviking's Avatar
Skiviking
Hey Thanks to all that answered!! It was a great help! I'm sorry forgot to state it was a 83 928S. Now to go remove it.
Old May 18, 2008 | 12:57 AM
SeanR's Avatar
SeanR
Love that avatar man. Nice.
Old May 18, 2008 | 09:23 AM
Skiviking's Avatar
Skiviking
Default Thanks
Thanks Sean, It makes me laugh evertime I see "Crazy Frog"
Old May 18, 2008 | 11:28 AM
Sailmed's Avatar
Sailmed
From: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
And sometimes just prying their hands off is the easiest way to remove them.....
Old May 18, 2008 | 12:12 PM
marton's Avatar
marton
about
HTML Code:
remove them.....
Actually this is just one of a series of increasingly expensive & complex solutions; the final step is divorce which is also the most expensive & you probably lose the 928 anyway
p.s. Before you completely remove the nut - pull on the steering wheel to get it loose; If you wait until the nut is completely removed then you have a good chance of smacking yourself hard in the face.
Marton
Old May 18, 2008 | 12:16 PM
Shark Attack's Avatar
Shark Attack
And WATCH OUT that you do not let your horn wire wrap around your socket and rip off.
Old May 18, 2008 | 01:05 PM
Skiviking's Avatar
Skiviking
Default Thanks again..
Originally Posted by marton
about
HTML Code:
remove them.....
Marton
Thanks Martin, I had hoped since I own a couple Quattro's that Porsche and Audi would used the same size nut...fat chance! lol
Old May 18, 2008 | 01:29 PM
PorKen's Avatar
PorKen
Inventor
27mm - also used for the crankshaft bolt.
Old May 18, 2008 | 03:00 PM
F451's Avatar
F451
And one of the the oil cooler line nuts (collar nut?) going into the radiator, along with the other nut (?) 32mm. At least it is on the S4.
What are those fittings on the end of a hose called? Its not really a nut is it?
Oh, and the 27mm nut is also used on the KTM dirt bikes rear axle, in case you have one of those.
Old May 18, 2008 | 03:12 PM
SeanR's Avatar
SeanR
Also used for the air pump fitting going to the cats, this is assuming someone still has cats and not an X-pipe.
Good advice on how not to smack yourself in the face also. Never would have thought about that.
Old May 18, 2008 | 05:25 PM
UKKid35's Avatar
UKKid35
Well not quite, the crankshaft bolt is typically removed with a deep socket, but a deep socket doesn't fit in the steering wheel, you need a standard socket on an extension.
