What I broke at the Track Day
My cruise control....it worked fine last time I used it months ago....but wouldn't do anything on the way to or from the DE...... Its an MY 88 so it has the "electric" vs the vacuum driven unit..... I'm gonna have to spend some time looking up cruise control failures...
And ideas on where to start?
DE's are all about conserving MOMENTUM the cruise is great at that!!
Andrew
It looks like the stop lamps fuse #4 also runs the cruise....since my brake lights still work (or at least nobody hit me at the track day or a warning light) I'm guessing its okay....the bummer is pirtles write up is about a vac driven cruise system, not the electric one I have?
Under the Lift
The late model cruise still relies on vacuum to pull the cable [See correction below for 88MY onward!], but I would think you would have other problems if that had failed, so, yes, look for electrical issues first. There is a CC brain.
The Parts Whisperer
Unless I am misunderstanding you (quite possible) the cable from 1988-1995 is pulled by an electric servo not the vacuum cannister used in prior years.
Under the Lift
Thanks for the correction.
Under the Lift
OK, I guess I found out how my misconception came about. The person that told me about the vacuum and CC owned an 87 but should have been very familiar with all MYs (that was his job). He told me this in reference to a vacuum issue I was having with my 89, so I thought it was at least all S4s. However, here is the catch:
OKAY I just printed it out...pages 386 through 392 of the WSM on CD.....goes into great detail about diagosing everything..& yes I do have the electrically driven cruise.... After reviewing it man does it bring back memories of tracing down my failed fuel pump via a no start issue....
Looks like I'm in for some quality time with my trusty fluke!!!
Team Owner
brian didnt you just replace the turn switch? If you did is it possible that the CC didnt get hooked up or has come apart?
