Which electric fan to replace viscous fan?
Bumbling Neophyte
Going to do the Porken tensioner upgrade soon, might as well remove the OEM viscous fan and replace with a electric. DR says 17" 2000 min CFM in front of the rad. Hayden 3817 meets this req but is over $200 from Napa ( and a "special order") , anybody got another fan tried and true for this app?
TIA KK
TIA KK
Rennlist Sponsor
Don't pay that much for that fan! You can get the basically same fan at Summit for $83 (see link)
http://store.summitracing.com/partde...5&autoview=sku
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
Rennlist Sponsor
Also here is a 3000 CFM fan from Summit for $97, it is a little thinner too (3.5 vs 4")
Bumbling Neophyte
Many Tanks Dave. Please give Thor an extra doggy (extra large) doggy bisciut and tell him its from me! I'll rembusre the expen$e (he's a big dawg!) at SITM.
KK
KK
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Bumbling Neophyte
This 3000 cfm is only a puller, do I flip it to become a pusher or buy the next one down (97 vs 118) I don't care about the $20, Just want the best option.
Thanks KK
Brand: Zirgo
Product Line: AutoLoc Zirgo Ultra High Performance Electric Fans
Part Type: Fans, Electric
Part Number: HFM-ZFB16S
Maximum Fan CFM: 3,000 cfm
Fan Quantity: Single
Fan Diameter (in): 16.000 in.
Height (in): 16.700 in.
Width (in): 16.000 in.
Thickness (in): 3.500 in.
Number of Blades: 10 blades per fan
Blade Material: Plastic
Blade Color: Black
Shroud Color: Black
Shroud Material: Plastic
Amp Draw: 10.00 amps
Quantity: Sold individually.
Electric Fan, Single, 16 in. Diameter, Puller, 3,000 cfm, Black, Plastic, Each
Brand: Zirgo
Part Number: HFM-ZFBC16S
Blade Color: Black
Shroud Color: Chrome
Electric Fan, Single, 16 in. Diameter, Pusher/Puller, 3,000 cfm, Black, Plastic, Each
Thanks KK
Brand: Zirgo
Blade Color: Black
Shroud Color: Black
Brand: Zirgo
Blade Color: Black
Hey guys...long time no talk
Anyway...this is the first time I see a 2000 cfm fan drawing less current than the 2000cfm fan. I'm hoping it's a typo, otherwise the cfm ratings may be suspect....or the current draw numbers are inaccurate...unless I'm missing something here
Tarek
Tarek
Bumbling Neophyte
Both fans have the same specs 3000 cfm @ 10 amps 12 volts = 120 watts, just one looks to be pusher/puller ($118) and the other is just a puller($97). Unless your thinking of a different brand? Us Southern Gents have different requirements than the northern ilk, no need for "climate control" just flip the AC on full from April through November, so the biggest/highest CFM fan I can fit in is what I want.
My gut says puller behind the rad, just like stock, but...
Thanks KK
Thanks KK
FWIW I have not had very good luck with Zirgo fans. Two different examples the propeller would not stay attached to the shaft. I now have a Spal, which I got from Carl. So far, so good.
Administrator - "Tyson"
FWIW I'm personally installed a few dozen Zirgo fans on 928's, so far not one issue to report.
I run the AC 12 months a year down here in Clearwater...yes even in cold Jan/Feb days.
As for the fans, I was making a comparison between the 3000 cfm units and the 2000 cfm (same brand) unit in the first link. Something just doesnt sound right when amp draw drops as cfm goes up for the same manufacturer. One of the claims (either cfm or amp draw) is not accurate...generally amp draw rises with higher cfm...again, just my observation. Just thought I'd point it out. Good luck with upgrade. I generally use Spal every chance I get, but they are pricey.
Tarek
Tarek
Thanks KK
Thanks KK
Road Warrior
fwiw, devek has a cool dual spall 1710 setup w/an aluminum shroud... seems to work in socal heat/traffic w/out issues, even w/a built motor/headers, dual ac on, etc...
iirc, the biggest issue is the pulley that gets left out w/out a fan pulley.
