928 Forum 1978-1995
Sponsored by: 928 Specialists
Should I purge the OLD gas?
Old 05-06-2003, 06:12 PM
Gregg K
Gregg K's Avatar
Post Should I purge the OLD gas?
How imporant is it to remove ancient gas from a car that sat for a few years?
Does the fuel flow in a circuit where it returns to the tank. If so, I'm all set to go without doing anything but filling the tank. Jeez, such rookie questions. (Well, this is my first fuel injected vehicle.)
Old 05-06-2003, 06:22 PM
Mark
Mark's Avatar
Post
Gregg -
YEARS????
Even gas that has had treatment added, like StaBil, is good for less then 12 months!
I would drain AND flush!
Old 05-06-2003, 06:26 PM
Greg86andahalf
Greg86andahalf's Avatar
Post
If you pull the fuel guage sending unit from the hatch area, which is an easy procedure, you can easily syphon the fuel out of the tank and also clean the sending unit of gunk and varnish.
A new fuel filter would be something to think about.
Greg
Old 05-06-2003, 06:29 PM
Gregg K
Gregg K's Avatar
Post
The tank is completely empty. Can I just turn on the ignition and have the gas recirculate into the tank? I mean, the manual has one pulling solenoids and jumpering terminals. It has to be easier than doing all of that.
Old 05-06-2003, 06:30 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
Post
I would drain the tank put in a couple gallons of fresh fuel run the pump to flush the lines a bit drain the tank again ..put in a couple gallons more and try to start it . Any number of additives may be usefull to help clean the fuel distributor and injectors but wait until you have it running and can add more fuel .
Old 05-06-2003, 06:46 PM
Cobey
Cobey's Avatar
Post
Silly question, but what do you do with all the old gas? When I picked up my shark, I thought it was on empty after having sat for a year. After getting to a station and putting in a couple gallons, I discovered the guage had just been stuck. So now I have a tank full of old/new gas that I will need to clean out.
Old 05-06-2003, 06:55 PM
Gregg K
Gregg K's Avatar
Post
I put the old gas in either my old '61 Case backhoe. Or I put it in my crane, which has a 50 gallon tank. But some auto repair shops have tanks designed for gas disposal.
Hey, thanks you guys. This forum is fantastic. I'll be a member just as soon as I'm convinced I'm a 928 owner AND driver. haha.
Old 05-06-2003, 06:58 PM
tresamore
Photoshop Bully
tresamore's Avatar
Post
Even after a drain and flush there may, I repeat may be some issues. You may not have to do any of the following things, I'm just throwing this out as an example. That said, I bought a Kawasaki road bike many years ago that was inside a barn, leaning against a wall for 3+yrs. I had a hard time making it run well after I had drained and filled it w/ new gas. I ended up taking the carbs out and in the bowls, were varnish patterns from the bottom to about 2/3s of the way up and ended in a diagonal pattern across the bowl. After cleaning it out, (soak in carb cleaner) I realized it was from the way the gas sat in the bowls as the bike was leaning against the wall. If your 928 has been sitting for a similar time, you may have to drain and add a concentrated mix of gas/carb cleaner and hot wire your fuel pump to run w/o the car running. Something strong enough to dissolve the varnish in the system, but not strong enough to damage anything. Then after that I would use a heavy duty injector cleaner setup that mechanics use that comes in an aerosol can. You disable the fuel pump and the can connects to the fuel rail. The car actually runs off the pressure in the can. By the time the can is empty your injectors should be clean. Maybe it would take a few cans if they're really bad, I don't know. Good Luck. <img border="0" alt="[blabla]" title="" src="graemlins/a_smil17.gif" /> <img border="0" alt="[typing]" title="" src="graemlins/yltype.gif" />
Old 05-06-2003, 07:44 PM
Cobey
Cobey's Avatar
Post
Hey Gregg, wanna bring that crane by for a free fill?
Old 05-06-2003, 08:51 PM
Gregg K
Gregg K's Avatar
Post
Cobey, that's funny. I used to live in Los Gatos, and actually drove the thing thru the east bay when I moved up this way. It's pretty cool. Four wheel drive and all.
Tresamore, I know just what that looks like, and I'm prayin I can just start this and not have that kind of headache. Something tells me this is going to be a piece of cake. I mean, so far this car is like, well, NEW. I'm so blown away at the deal I got. So, if the fuel is a problem, I can't complain anyways. I've got a bottle of Techron in it now. Fingers are crossed. Now if 928int will get the oil filter to me........ Thanks
Old 05-06-2003, 09:27 PM
Mark
Mark's Avatar
Post
Gregg -
Surely there's a local foreighn car parts store with the oil filter - you can ALWAYS use the one you have on order later!!
I by mine locally at a little auto parts store that specializes in VW's. It is still the OEM filter...
Old 05-06-2003, 09:57 PM
Gregg K
Gregg K's Avatar
Post
Nope. There isn't even a Porsche dealership in the entire county! But that's why I like it here. This is pickup country. None of them furin cars around here. The more I hear the fanaticism from you guys, the more excited I get about driving this car. Remember, I've waited since 1981! That's the last time I had a car. I spent 15 years driving a '55 Chevy pickup. But that's another story.
Old 05-06-2003, 10:19 PM
Mark
Mark's Avatar
Post
Well Gregg -
Get that shark going!
Remember---
Microsoft: "Where do you want to go today?"
Porsche 928: "How fast do you want to get there??"
Old 05-07-2003, 12:53 AM
Cobey
Cobey's Avatar
Post
Are you sure you won't come by Gregg? Thoght we could use the crane to help change a t-belt. <img border="0" title="" alt="[Wink]" src="wink.gif" />
Old 05-07-2003, 12:19 PM
Gregg K
Gregg K's Avatar
Post
Well, alright. But let me change the oil first.
<img src="http://www.pacificsites.com/~gkuljian/digpics/crane.JPG" alt=" - " />
Quick Reply: Should I purge the OLD gas?
