Fuel Dampner 928.410.429.07 ? no it's a vacuum limiter, PN 928.110.173.01
I have that same regulator on my crossbar (MY86.5) and it is part of the smog system. Before my intake R&R, my vac hose came off. It connects to the 7 way splitter under the intake in the Vee. I think it will affect performance if not working properly or if there is a vac leak from its being disconnected
Hot start problems can be caused by a faulty Temp II sensor or corrosion at the connections. All that it takes is an ohm meter and a guesstimate of the engine coolant temperature. Measure the resistance values at the Temp II sensor and at the LH/EZF connector.
Note the orientation of the protruding alignment notch on the outside of the sensor. Prong 1 is the sensor for the Electronic Ignition and prong 2 is the sensor for the LH fuel injection. Clip one of the ohm meter leads to prong 2 (LH) and clip the other lead to a ground point [Do NOT connect the ohm meter leads between the two prongs of the sensor]. Repeat the resistance measurements for prong 1 (Electronic Ignition). The proper Temp Sensor II resistance measurements are:
0 C / 32 F: 4.4 - 6.0k Ω (Ohm)
15 – 30 C / 59 - 86 F: 1.4 to 3.6k Ω
40 C / 104 F: 0.9 – 1.3k Ω
60 C / 140 F: 480 – 720 Ω
80 C / 176 F: 250 – 390 mΩ
If the resistance readings are not correct range, the temperature sensor must be replaced.
If the resistance readings are in the correct range at the sensor, there could be a problem with wiring to the LH controller or the connector itself could be corroded. Measure the resistance from the Temp II sensor connector to the LH and spark controller connectors to confirm the circuit is good.
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
That is 944 110 429 00 "control valve" it is part of the fuel vapor charcoal container system and under certain conditions it pulls air through the container to purge the accumulated fumes. It MIGHT be an unmetered air leak into the intake if it is malfunctioning ???? Try blocking off both of the big hoses.
Jason your car does not have that BUT you have a similar looking "idle valve" solenoid which opens when the A/C compressor is turned on. If removed b;ocked and you turn on the A/C the car may stall idle slow.
Inventor
I want to thank everyone who responded and provided insight/help. My problem turned out to be caused by bad injectors. One specifically had a broken tip sleeve. I'm off and running again. Thanks again
Tarek
Tarek
If it is indeed knackered, is it the same part as 944 110 429 00 as I can't find the 928 110 429 07 in PET or on the usual suspects websites? And is it really $700!!?
Team Owner
Mervy please post a picture of the part your talking about
![](http://i1109.photobucket.com/albums/h438/mervynp/valve.jpg)
This is the little swine. The position is as shown in Fabios picture and it looks like the hoses connect to the engine just below the oil filler cap and then on towards the carbon canister respectively, which makes me think this is part of the vapour control system, but I have been wrong before.....
Thanks,
Steve
Team Owner
it should hold vacuum,
and when vacuum is applied the 2 bigger lines should be open to pass fuel vapors.
Mr Merlin,
many thanks for all your help, I got a replacement that does indeed hold vacuum and it is all plumbed up.
Now for the next problem, the black plastic valve that the above one is connected two, which I think is for the carbon canister, also does not hold vacuum, so I removed it by spending an hour or so cursing and swearing at it before removing the wheel well lining and pushing the hose through from the other side.
I can now test this, if I pump the small control pipe with the mitivac it opens the valve, it seems to stick a bit and doesn't always close but that aside is this normal, my guess is yes.
I am a little concerned that this is a VW/Audi part, not that there is anything wrong with that.
I am also a little concerned that this is then blocked with a bit of black electrical tape at the top of the Y connector. Badly. I think I should take this blockage out, but people don't block pipes for no good reason and am scared of what this is hiding. Any thoughts?
Cheers,
Steve
Cheers,
Steve
Sorry to dredge up an old thread…
I have the same problem that mervynp has encountered. My 928.110.429.07 "Control valve" will not hold vacuum.
![Name: _DSC0014.jpg
Size: 42.6 KB](https://rennlist.com/forums/attachments/928-forum/752488d1376454694-fuel-dampner-928-410-429-07-no-it-s-a-vacuum-limiter-pn-928-110-173-01-_dsc0014.jpg)
After scouring Rennlist about this part, this is what I have learned thus far:
This control valve is part of the fuel vapor charcoal container system and under certain conditions it pulls air through the container to purge the accumulated fumes. It will affect performance if not working properly, or if there is a vacuum leak from being disconnected.
It should hold vacuum, and when vacuum is applied the 2 bigger lines should be open to pass fuel vapors.
Since I don't really want to spend $700 for a replacement part…
What happens if this part does not hold vacuum? What does "it will affect performance" mean, exactly- does anyone know?
