Sharktuner SMAF usage
#46
well..i cant get it to start....the file i have on the PEM is 38.6 fuel injectors. Im trying to eliminate rich starts and a rich idle with all the cells in the area at -128 . Has ran fine for ages and has put good numbers down, but i have never had 42lbs selected.....cant recall the reason why either
#47
As Jeff rightly says that difference in nominal rating will not cause what you see/report. Remember the nominal poundage rating of the injector is the amount of flow/hr at a specific pressure which as I recall is less than the system pressure used by Porsche in our 928s. Obviously the bigger the injector the more the correction needed. The general idea is to get the "injector sizing correction" such that the deviation from zero is minimal across the board as it were and thus it makes sense [to me at least] that the injector rating dialled in to ST2 may well be a bit less than the nominal rating you understand the injector to be.
When the adjustment is maxxed out [as you report] the correction from zero is 25% in flow terms. Your nominal injector sizing offset is nominally 10% so the adjustment range should more than compensate. If it cannot compensate as would appear to be case then logically something else is wrong- incorrect Temp2 resistance values for instance? I doubt that would be the problem as your ambient temps are currently around 7C so notmuch scope for substantial error but...?
#48
If the injectors are spec'ed at 42# (at the usual 39.5 psi spec pressure) then setting Sharktuner lower will flow more fuel. The LH calculates the required fuel and therefore the pulse-width, if you tell it a smaller injector then the calculated pulse-width will be longer for that amount of fuel. Again, not a lot, but in the direction of too much fuel.
The other big variable at idle (once the engine is running) is injector opening-time. For stock injectors, this should be 0.94ms but will be slower or faster for other injectors. That's also a hard spec to come up with, it can be extracted from the spec-sheets for Ford Motorports-branded injectors but not most others. For the Ford M9593-F302 42# injectors the opening time at stock 55psi pressure would be 0.99 ms. That's only a small difference from the stock 0.94ms and would result in less fuel, so not likely the issue.
And Fred, you are correct that injectors flow more fuel at the 55psi pressure for '87+ cars, but the ST injector-size settings are based on the nominal flow at a standard test-pressure (2.7 bar = 39.15 psid). So the stock 19# injectors actually flow 22.5 Lb/hr, and the 42# injectors actually flow close to 50# at 55 psi, but that doesn't matter-- Sharktuner goes by the nominal flow-rate compared to 19#.
#49
Hi,
The first thing I did before running the engine was to burn an EZ-K chip with retarded timing so I could tune the LH without the ignition timing being too far advanced for boost. With the ST connected to the EZ-K, and the base map up for the GT, I started at about the 50% load point and reduced all RPMs (the entire load row) by 0.8 degrees. That's two clicks on the single "-" button with the entire row selected. Select the next row down and do the same except this time use 3 clicks for a 1.2 degree retard from normal timing. Go on down to the bottom (100% load) row retarding in increasing steps to have about 9 degrees retard all across for that row. I was striving for a gradual timing retard at above 50% load to end up at 9 degrees retard at full load. This more or less conformed to the rule-of-thumb 1 degree retard fo reach pound of boost theory. It turned out to be pretty close except I should have retarded more than the 9 degrees on the initial EZ chip.
Louie
Louie
#50
The WOT map is the most critical, but you''ll be surprised how little time you spend there except for that last exciting part :-)
GregBBRD (08-26-2023)
#51
You really need to retard cruise as well as WOT. That's because you will be running through much of the rev and load range as you wind open the throtlle to get to the desired rpm and load.
#52
Hi,
Louie
Louie
#53
Brett, I am not sure why "Edit RPM Axis Points" is circled, but that is not the adjustment you want at this point. Louie was talking about reducing the ignition advance in the "boosted" part of the map. (He was also talking about the original Sharktuner. The ST2 can talk to both EZK and LH via the PEMs-- just select the "Ignition maps" page as you have done).
So start by selecting the 53% row-- click the "53%" cell to the left-- and verify that the entire row is selected (highlighted). Reduce the timing for that row with two clicks of the single-minus button, which will be around 0.8%.
And you are correct, 7 more rows each retarded a further 0.4 deg is not going to get you to 9-deg by the last row. So jump to that last row next, reduce timing by 9 deg, and then go back and retard each row to make a smooth progression. So maybe the lower-right corner (max RPM, max load) winds up 17 or 18 deg instead of 26.7.
This is just a starting point, a wild guess. The point here is to take out some timing so that the EZK doesn't exceed its 9-deg knock-retard limit. And going back and forth between LH (for fuel optimisation) and EZK for timing adjustments is simple.
Then, as you get fuel dialed in for higher loads and RPMs, watch for EZK knock-retards. Sharktuner software will beep if the computer audio is enabled, and you should reduce timing further as needed. Also, logging data and looking at it with Sharkplotter is very helpful, This will show you where the knock-retards are occurring on the ignition map, and how much and from which cylinders the EZK is backing out timing. A few cylinders retarded by a few degrees is fine, but all cylinders retarded by 9 degrees is definitely not what you want to see. Then once you get that dialed in, start adding advance back in for cells that weren't getting retarded by EZK. Basically, you are probing the knock threshold which isn't necessarily max power or efficiency, but it will be close-- and doing better requires hours of dyno time.
Generally, there is no need to shift the RPM axis points with a stock intake and flappy. The scaling is compressed around 3000-3400, that's where the flappy is flapping and the torque peaks are, and timing requirements change over a smaller range of RPM. That can be changed, but get the basic tuning done first and see what the map looks like.
Edit: A further thought on the WOT map: Normally the EZK switches from the main map (the "cruise" map) to the WOT map, whenever the throttle WOT switch is activated. So the WOT map should also be retarded by the same 9-deg as the last row of the main map. However, many folks (including Louie) don't bother with the WOT map and disable it, and use the main (cruise) map for everything (except idle). So IF you leave the WOT map enabled, then be sure to reduce the timing there too.
Cheers, Jim
Cheers, Jim
#54
That was the 1st image I could find of the ignition maps screen, and that was already circled.
Thanks for the clarification. It makes much more sense to me now.
#56
