Engine building question
anyway, long story short, he finally believe me , but not that we could have near .001 of clearance between piston and cylinder.going off the spec, there is about .035mm, which is just over .001". (for the 2 valve engines) So, why is the spec just under .001 for the S4????? (spec is .020mm, which is under .001") i know this is measured from the 90degree from the piston skirt position, so , what is the clearance at the skirt??
Last question: If we nicasil a block, and the coating is real hard as they say, how does thermal expansion work if alusil expands a lot with heat, and the pistons are not forged and are susposed to expand at near the same rate? does the coating on the cylinders expand at the same rate as the block material? are the piston vs cylinder dimensions the same stock, or does a nicasil block with JE pistons , for example, require difference clearances?
mk
So, why would you want to make the pistons smaller than the spec?
anyone know what the diameter difference is for our pistons as measured at the skirt vs the front and back of the piston?
mk
I should have measured the cylinders before i assembled.
mk
It's possible Porsche learned how iron coated pistons reacted during heat cycles and figured out they could tighten up the clearance based on the stability of the alusil. My guess...
Nickasil is used in all kinds of bores these days. But most often they seem to be used with forged pistons. Refering back to Brians post, the bore clearance may be subject to the piston material and growth rate not the block.
Am I even close?
Maybe it is as simple as the bock material (same for S4 or early 4.7) so, it boils back to the piston.
What happens when the coating is nicasil, does the clearance have to be increased? (and if the pistons are JE's, does that mean they are forged?)
mk
If they are familiar with Alusil and have done four banger blocks before then they should know correct specs for 5L 928 also.
Engines that slap will wear out quicker than engines that don't, you don't need to run 2618a pistons unless you are running lots of boost pressure. Even some F1 engines recently experimented with 4032. The strength is not that far behind and it is only certain characteristics of 2618a otherwise known as Rolls Royce 58 that are superior, the link will provide a bit of history. http://www.accralite.com/accralite/rr58.htm
In short the Nicasil will expand with the alusil as it is bonded to it and the coating is very thin, it should not affect the clearance, just go and check what the current GT3 piston clearance is or even the Carrera GT, that will provide some insight I think.
Greg
