928 Forum 1978-1995
Sponsored by: 928 Specialists
Overfill AT
Old Mar 31, 2008 | 08:32 PM
soontobered84's Avatar
soontobered84
Default Overfill AT
Besides the obvious reason of AT fluid all over the floor of your garage, is there any good reason not to overfill the AT?
It wouldn't appear to cause the same issues as overfilling the crankcase with oil.
Old Mar 31, 2008 | 08:43 PM
Lizard928's Avatar
Lizard928
the real question is why are you asking
Old Mar 31, 2008 | 08:55 PM
928drvr86.5's Avatar
928drvr86.5
You will over-pressure the supply line to the transmission cooler and a leak will most likely occur at the hardline-hose transition between the torque tube and passenger side frame rail. Or, that is at least what happened when I overfilled mine years ago.
Old Mar 31, 2008 | 09:49 PM
soontobered84
Just stupidly curious
Old Mar 31, 2008 | 11:06 PM
Ed Hughes's Avatar
Ed Hughes
said the curiously stupid fellow.
Old Mar 31, 2008 | 11:21 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
if your tanks clean then you should have no problem seeing the correct level, with the engine running in park
Old Apr 1, 2008 | 12:24 AM
soontobered84
Ed,
you need to fix your avatar. The white car is now in the Northern climes wondering why it's not being driven.
Old Apr 1, 2008 | 12:27 AM
ROG100's Avatar
ROG100
Basic Sponsor
John,
Get down from the tree house with the young ladies and get under your car and check the ATF level the way it should be checked.
Roger
Old Apr 1, 2008 | 12:34 AM
soontobered84
No really guys. The treehouse was a lot of fun....oh....I mean I filled it up properly. I really was just wondering. And by the way, those young ladies were of age.
Old Apr 3, 2008 | 03:10 PM
soontobered84
Ben, Why would overfilling the reservoir increase the pressure in the system? It just seems that the pump will have a maximum pressure regardless of the volume of the reservoir. I'm not saying you are wrong or trying to start an argument of any sort. I just have always heard " Don't overfill" but fail to understand how it would be bad for the tranny.
What if you put a larger reservoir in place of the stock one? That shouldn't damage the tranny, which in effect, is what you'd be doing by overfilling.
I know it sounds silly, but I just want to know.
Old Apr 3, 2008 | 03:32 PM
PorKen's Avatar
PorKen
Inventor
IMHO, the pressure of pumping oil through the 20+ feet of small diameter pipe/hose, combined with banjo fittings at the transmission is a contributing factor in flexplate creep. (Even at the stock fill level.)
My old '86's flexplate stopped creeping when I put in a rear cooler, and straight through fittings. I have yet to convert my new '86, and it's flexplate moves the regular 3-4mm after a short time.
Note that the four speed has a thermo-valve inside that delays shifting when the oil is cold, which is annoying if you install just an air/oil cooler, I found. This time I'm going to use a thermostat, along with a cooler with an integrated fan.
Old Apr 3, 2008 | 08:07 PM
Ed Hughes's Avatar
Ed Hughes
Yes you are.
Old Apr 3, 2008 | 08:22 PM
SeanR's Avatar
SeanR
So, John,
Did you, or did you not follow the WSM on the proper way to fill a transmission?
I could have talked you through it instead of 10 phone calls to others and a post here.
Old Apr 3, 2008 | 08:25 PM
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mine is overfilled. It used to leak a lot after the car was shut off. Now it doesn't leak much, but when I get the ATF hot, it will come out of the cap, compromising the seal. The wind also picks it up and mists it onto my exhaust pipes causing this lovely caked on crust...
My transmission service is coming up soon, so I'm going to synthetic and making sure the fluid level is correct so it will never happen again.
Old Apr 3, 2008 | 08:30 PM
Ed Hughes's Avatar
Ed Hughes
Actually, the AT is the least of John's problems. Sean's driveway is evidence of what too much oil (apparently, as the engine was REJECTING it!) does....
