928 Forum 1978-1995
Sponsored by: 928 Specialists
Need alignment specs badly.
Old Mar 21, 2008 | 05:08 PM
drnick's Avatar
drnick
i wonder what they are referring to with the rear pick up points?
Old Mar 21, 2008 | 05:45 PM
mark kibort's Avatar
mark kibort
The specs on the 928 from the hunter machine, ive seen range from .25degrees like shown on this thread, and .5 degree max on the other thread, and on my alignment sheet off a huntermachine.
I know the racing specs might be different, slighly, and really only in areas of the camber. look at the toe. toe'd in in front .15 degrees and toed in in the rear only about .25 degrees. about where most street cars and race cars are set. caster is a little futher forward at 5 degrees where most of us are in the 3.8 degree range. im at 2 degrees camber all around for the most part.
Mk
Originally Posted by Bill Ball
I don't know where 0.5 degree comes from. Racing specs can be a lot different than street. Take a look at these specs and comments for the 928 Cup.
Old Mar 21, 2008 | 05:49 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Pick up points refers to mounting point of the control arms.
Old Mar 21, 2008 | 08:58 PM
mark kibort
so, why the change on some alignment sheets spec'ing out the max rear toe in to be .5 degrees.
this sheet says .25 degrees. whats up?? did it change in the later years?
mk
Old Mar 22, 2008 | 01:22 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
What alignment sheets show 0.5? I missed that.
Old Mar 22, 2008 | 03:06 AM
mark kibort
https://rennlist.com/forums/showpost...11&postcount=1
File Type: jpg
