THE OFFICIAL: E85 Fuel Conversion Thread
#61
I forget what controller you said you are going to run. Maybe this is important or not, it depends on the controller. Make sure you don't run batch fire injection. If you try and fire 8 injectors that big at the same time the rail pressure drops dramatically. Sequential injection is the only way to go when you are running big injectors. It dramatically helps idle quality as well as on the top end.
Both can do individual trim, ala sequential injection and ignition.
#62
but they dont run on E85 which Hacker if you were paying attention you would know requires more fuel.
I knew you couldn't go without posting and mentioning Murf LOL, Honestly if you hadnt i would have thought something happened to you. Glad to know your still alive up there after #4's retirement.
#63
Pretty sure we have already outlined that E85 in a standard 928 fuel system is not a good idea....
If anyone wants to give that a try, then that's their decision and hopefully they will let the rest of us know what fails... (I hope no one does.... but...)
Whether or not to use E85 will have varying reasons for many people...
As a fuel to assist with tuning for monster HP boosted applications such as Brendan and Ryan are suggesting, to appear green, economics... whatever, that's more of a discussion for OT...
Personally I have been considering this conversion, preferably in a boosted application, (but I don't think my finances will allow this any time soon)... so I would like to try and incorporate onto a more or less stock, non-boosted engine with appropriate fuel system upgrades and preferably an increase in comp. ratio.
Note... I wouldn't be doing it purely for the HP...
An increase in fuel pressure or SLIGHTLY larger injectors, as well as a decision on a different tank, and replacing the little rubber that exists in the system are the only concerns in NA.
Does anyone have an OEM fuel rail handy? Can they see inside it?
#64
Yeah costs have been exagerated a bit, but it's still not exactly cheap...
That said, majority of the parts required, you would be purchasing already if you happened to be installing a form of forced induction....
In my case I estimate the biggest costs to be a shark tuner and probably the fuel tank....
Checked the fuel lines on my S4 and they are definately steel with some kind of outer coating.
Steel will still work, but eventually corrode away, I guess because ethanol is electrically conductive it is 'galvanic corrossion' that does the most damage to metal components....
Is the only way to increase compression ratio on a 32v to change pistons?
I'm guessing there would be valve/piston clearance issues if you attempted to deck / shave the head?
#65
#66
Perhaps Porsche changed material specs on those lines at some point (or its a ROW - USA thing)... mine are steel.
Or I have one of those special magnets that Kibbort needs, to see if his intake is aluminium![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I'll have to do more investigation on the compression thing.... I've got no idea what a standard gasket thickness is...
#67
Indeed. I am strictly talking about the green lines that run under the car, and I could easily be wrong, as I am working from memory, as I no longer have these lines.
#68
Administrator - "Tyson"
What worries me the most is fluctuating octane levels. If you tune the car for 110 today, then next week the pump down the street is 100 octane, that could be a problem. There is no guarntee that E85 will always be a certain octane level. In colder areas they are dropping it down to E70 or lower during cold months.
#69
With aftermarket EFI, the GM sensor that tests levels of ethanol (or maybe 02) in the fuel would be able to compensate. Without that sensor, yes, that is a problem. Here, in San Diego, I do not believe they change back and forth. Its always between 50 and 100 here. Mostly between 65-85.
#70
I know this is tangential from topic but I put E85 in for 2 tankfuls (in an E85 compatable Tahoe ) and compared cost per mile :
E85 @ 2.69 was 21 cents per mile
87 octane regular @ 3.10 was 20.5 cents per mile.
E85 for just reg driving is no bargain...but for your boost project seems just the ticket from reading our thread!
Andy
Andy
#71
When an engine is not designed for it, and its not tuned for it, and you get no power boost from it, no, other than technically burning cleaner, and being a renewable resource like any bio-fuel, no - its not that great.
#72
Former Vendor
I have a 1980 Euro that I will be putting a hybrid motor into. It consists of a 5.0L short block from a 1985 car (balanced and pistons notched) that will be mated to a 16v 4.7L euro spec top end. It is essentially a duplicate of the race motor David Lloyd runs (ran), as he did all of the prep work for me. CR is expected to be 11:1. Hence my interest in E85. Would be PERFECT for my application.
Does anyone know whether the early 16v cars had steel or plastic tanks? I know the 924s of that era are all steel, and those didn't change over until somewhere around 1985 (or later) in the 944/924S. That would be a huge variable out of the way for me.
As for the fuel lines, I'm not concerned about any of the steel lines. I would simply replace any of the rubber or neoprene lines with stainless.
Now for the kicker: since I would prefer not to switch over to EFI, and would like to retain CIS, why not just run the UT-CIS programmable WUR, and set up a map specifically for E85??? I'm pretty confident the stock injectors will flow the fuel I need (target BHP is ~350).
Any thoughts on this? Seems like a pretty simple and cost effective conversion provided the tank isn't plastic:
- replace all rubber & neoprene as mentioned
- replace stock WUR with UT-CIS, and program accordingly
- maybe run a new / higher capacity fuel pump
- tweak timing
In my case, this would be VERY economical, as this motor essentially requires race fuel. The price differential on the fuel alone would probably pay for the conversion in a season or two...
Thoughts?
- tweak timing
Thoughts?
#73
...Every year is plastic. And its not a very strong plastic either. Thick though.
- tweak timing
Thoughts?
- tweak timing
Thoughts?
People will chide you for doing it, saying the fuel is bad, and its political ramifications are horrible, and that you don't need it. Tell them they can stuff it. 11:1 is reason enough. 5% more power from the increase in total burnable material is another.
#74
Former Vendor
Bummer about the gas tank. I didn't realize they were using plastic tanks that early. That in and of itself could be a serious inhibitor from a cost perspective...will have to do some real noodling over that.
Yes, I meant teflon-lined stainless steel flex lines.
Interesting note about the lubricity factor...I've read a little about it, but hadn't given consideration to the potential impact on the CIS fuel distributor, as my other planned application is on an EFI-converted 931. I'll definitely take into consideration the Redline lubricant, probably not a bad proactive measure to take.
Any thoughts on the UT-CIS approach to adjustability of the fueling?
As for the naysayers, trust me, I've never let them stop me from figuring out solutions!!! And I could care less about political correctness. The car is going to run race fuel anyway, so economy and ecology aren't anywhere near the top of my concerns ;-)
#75
The plastic tank may survive in the short term. But you should pay attention to the galvanic action of the fuel in usage - in take pumps = NO NO. Its conducts electricity, and could cause issue in what I believe is certain brass pieces in the CIS? Don't quote me. But you pretty much want coated steel, coated aluminum, or telfon.
