928 Forum 1978-1995
Sponsored by: 928 Specialists
GT Oil Cooler Fitting Help
Old Mar 15, 2008 | 09:10 AM
UKKid35's Avatar
UKKid35
Question GT Oil Cooler Fitting Help
I'm about to retrofit a new Oil Cooler. I have the Oil Cooler itself (the most expensive part I have ever bought for my car), the two small brackets and grommets, and the oil cooler lines (and a new oil thermostat for good measure). I also have the large pressed moulding that goes in front of the cooler, although I'm not sure whether I need it. I'm also going to have to modify the S4 spoiler to allow airflow through to the oil cooler.
What would really help is any photos of the oil cooler as fitted to your GT or GTS. Thanks in anticipation.
File Type: jpg
Old Mar 15, 2008 | 09:32 AM
DR's Avatar
DR
Rennlist Sponsor
Here are a couple I found, will look for better ones for you. Note the oval holes in the factory spoiler for airflow to the cooler.
File Type: jpg
File Type: jpg
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Mar 15, 2008 | 08:07 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Paul-
I'm asking out of ignorance- does your front chin spoiler have the cutouts to vent air through the oil cooler? The spoiler part # changed in '90, not sure if it's because of these openings.
Here are some other pics of the cooler from various angles:
Oil cooler from above:
RHS mounting point from above:
RHS mounting point from below:
LHS cooler and oil lines:
The oil cooler rubber mounting grommets get old over time and pull through. Found this one day last year:
I seem to recall that the 10mm nuts that held the oil cooler ducting on were kind of a PITA in the turn. Here are the studs that the ductwork mount on:
Yell if you need shots of anything else!
Old Mar 16, 2008 | 03:39 AM
UKKid35's Avatar
UKKid35
Dave, thanks for the pics and for supplying the oil cooler.
Rob, that's superb - a huge help. Neither the spoiler nor the bracket directly in front of the cooler have cut-outs. I have the new bracket (for some bizarre reason it only cost £9 new from Porsche - I was expecting over ten times that), I will try modifying the plastic spoiler.
Old Apr 25, 2008 | 02:29 PM
UKKid35's Avatar
UKKid35
At long last here's my attempt at retro-fitting the oil cooler.
I didn't have time to pull the rad and replace the rubber stops, so the oil cooler is sitting slightly lower than it should.
Here's the pathetic aftermarket cooler that was fitted by the PO, not only is it too small to do anything useful, but there was no airflow through it anyway.
I haven't yet modified the spoiler, I doubt I'll be able to make anything other than round holes, and hopefully I'll avoid weakening it so much that it produces that typical GT grin.
Finally a big thank you to Roger who not only supplied the used Oil Cooler lines in excellent condition, but he made sure they were spotless before shipping them.
Old Apr 25, 2008 | 03:22 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Oh, how I'd like to do this to my 89 S4. The stock radiator with integrated oil cooler is barely up to task in open road racing. So, this requires the cooler, new hoses, the sheet metal and making some mounts and modding the spoiler for airflow. $$$$???
Old Apr 25, 2008 | 04:47 PM
bfellows's Avatar
bfellows
Paul, just curious as to why you need to run an oil cooler?
Old May 23, 2008 | 09:29 AM
UKKid35's Avatar
UKKid35
Don't forget all 928s have Oil Coolers, but the side tank oil cooler had failed some time ago. The PO installed the diminutive oil cooler in the photo, completely sheilded from any airflow.
A couple of weeks ago I was at the Ring and this time the GT Oil Cooler kept the engine temps under control, never above the upper white line even with ambient temps over 27deg and the air con switched on.
Also the oil pressure was maintained by the Penrite 15W-60, never dropping below 1.5 on idle.
Old Jul 16, 2008 | 10:02 PM
Dennis K's Avatar
Dennis K
Here's an addendum to this thread regarding the addition of a GT oil cooler to a non-GT or GTS car.
The radiator mounts in an S4 are made entirely of rubber where the GT/GTS mounts have a metal backing w/ a stud going down through the chassis. You'll need these "Gummimetallpuffer" mounts which are shown as an alternate part in the '92-'95 GTS PET catalog. The oil cooler attaches to the underside of these radiator mounts.
So in addition to the basic oil cooler parts shown in the '87-'91 PET here:
You'll also need these radiator mounts (Part #928.106.179.00)
Old Jul 16, 2008 | 11:14 PM
RyanPerrella's Avatar
RyanPerrella
I would try and paint that shroud deal that goes in front of the cooler. Its supposed to be black and i noticed yours is just bare. You may want to throw some paint on that, or not.
Old Jul 17, 2008 | 04:53 AM
PortlandTom's Avatar
PortlandTom
Sorry to hijack the thread, but I have a related question. Parts 2-8 in the PET diagram below are missing on my GTS. So, are these parts supposed to be present, or is the PET wrong? I know they're present on S4s without the separate oil cooler, but they don't seem necessary with the brackets on the separate oil cooler. And I don't see those parts on the oil cooler pictures posted above.
Thanks,
Tom
'93 GTS, 5 speed, Amazon Green
File Type: jpg
Old Jul 17, 2008 | 05:13 AM
UKKid35's Avatar
UKKid35
Agreed, part 2 is part of the oil cooler itself. The image you have posted is pre-89. Another part I can't find listed is the ducts/guides that are fixed to the sides of part 21 to prevent airflow escaping sideways.
Old Jul 17, 2008 | 11:34 PM
PortlandTom
Thanks for confirming my suspicions. I also noticed the ducts/guides are missing from the PET. Not sure if it's more disconcerting to have parts missing from the PET, or to have parts in there that shouldn't be.
By the way, the picture I posted is from the GTS PET. I checked the S4/GT PET, and parts #2-8 are marked for '89 and earlier. But rather than remove the parts from the GTS PET, they removed the comment!
Old Jul 18, 2008 | 09:17 AM
Vlocity's Avatar
Vlocity
Very Nice......
I really need to add an oil cooler to my SC car that sees a lot of track time.
Could you share the ball park price ?
Ken
Old Jul 18, 2008 | 07:41 PM
ROG100's Avatar
ROG100
Basic Sponsor
Total of about $900 - cooler plus hoses and parts.
Does not include the metal molding in front of the cooler.
