K&N MAF Sensor Urban Myths?
#31
Administrator - "Tyson"
...and, if it floats it must weigh the same as a duck, therefore the K&N filters were created by a witch!
#32
Nope..more like:
Porsche put the screens in the MAF to add turbulence to the airflow
K&N put screens in the filter to add turbulence to the airflow
Therefore:
Porsche = K&N
Are you saying that Porsche is bad???
Therefore:
Porsche = K&N
#33
Isn't this theory contrary to what many believe Porsche did with the screens in the MAF?....Theory being they were put there to disrupt the laminar air flow into the intake?
BTW..just for the record..I think the screens are only there to protect the maf wire and keep extra large debris from entering the engine..
My understanding is that the screens are there to promote a laminar air flow.....
I do agree with your other points. However, removing the screens does mess up the mapping of the LH ECU because the MAf will measure differently to when the screens are in place, this change may benefit your particualr engine, or may degrade power a little.
Every car is different, especially at the age they are now.
#34
928 Collector
Don't remember ..which probably means I didn't see a gain or a loss either way.....although..only one of my screens is off...and I do recall seeing dyno runs where 10 or so HP was gained without the screens..
Do I believe that any of this hocus pocus?..Nah...I use the K&N because I can clean and re-install...
Just like Mark K or Porken quoting dyno numbers...they all sure look good on paper...but when I take on Ken at the track..I'll make sure its a hot and sticky day with a track temp around 120 degrees F..
#37
Under the Lift
Every scientific filter test comparing K&N to a stock paper filter on any vehicle has shown the K&N to capture less dirt and restrict airflow more than stock paper.
One of the best tests published: http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm
Most cars do not have the MAF directly under the filter. That may be the problem with oil and MAFs in 928s.
#38
Received 1,631 Likes
#39
Inventor
![](https://members.rennlist.com/porken/smiley_vader.gif)
But Tom's right, in my limited experience, I've found that inlet air temperature affects dyno results, considerably.
If you show a loss or gain with or without the airbox lid, or K&N, versus stock, you need to show the A/F graph, too. Because the stock LH chips are rich up top, anything that leans out the MAF signal, with turbulence, or restriction, or ?, will raise the HP peak. Taking off the lid leaned out my A/F ratio a tad, and I made 316rwhp (versus 312) with the stock filter, but, IIRC, the torque peak was lowered (rich for TQ, lean for HP).
#40
Mustang airplanes had an "icing screen" in the intake before the carb. If it clogged heated air was routed in. I'm certainly not sure of whether this was to stabilize air flow or what. The guy I knew who was a Mustang mechanic is, unfortunately, long dead. In any case, a flow restriction in the form of a screen isn't a new idea.
#42
Fleet of Foot
witch to wood that burns; wood to duck that float hence weight of duck to witch = witch
for a street car any hp gain (if there is indeed any) with a non stock filter is somewhat negated with the first bag of groceries or ones most svelte passenger........weight is now the most hp robbing factor and unless your racing the car............who cares.
#45
Well since this thread has now deteriorated to complete tom foolery,
I only use enviromentally friendly Nivea products that I find in my wife's night stand so if a duck swims through the wake it naturally moisturizes and repairs damaged well uh...skin.
So what we really need is a hot screen with something like 110 volts, that way any oil would be vaporized and the heated air would stabilze any dyno factors for back to back runs.
Ken
If they both float, the K&N is the one leaving a Valdez-like oil slick killing all the migratory sea birds.
Ken
