Take notice of the crisscrossing marks (like hone marks but deeper) near the bottom of the bore and the solid line near the middle to top of the cylinder. The other 7 cylinders have what I consider to be normal hone marks.
Is this normal/acceptable? I'd like to hear your thoughts especially if you've rebuilt a 928 or other engine.
I"ve never rebuilt a 928. I'm in the process right now. The marks you see are what happens when the brittle hone stone breaks on the tool. The end of the stone, or a small bit gets pushed into the bore, and create serious ridges.
It comes from the operator not paying attention when he's honing. A simple mistake that happens all the time. It may seal, but it will never seal correctly. You will have high blowby, poor compression, and very likely oil fouling problems on that cylinder for the rest of it's days.
It happened to me on a boat engine many years ago. The hone comes up out of the bore, or the tip gets tapped on the webbing of the block at the bottom. However it happens it's from the hone breaking, and scoring the bore.
Brendan - The line is too thin to catch a finger nail but I can definately feel it as I run my finger over it. This is not the case with the other cylinders. It's hard to judge how extreme it is from the picture but all you need to see is the difference from the rest of the cylinder to know something doesn't look right.
These bores after the plating process (nikasil) are DIAMOND honed - thats how hard they are. To fix this, it MAY need to be redone. The contractor would need to be contacted. Or you could just run it.
Hehe, even worse. A bit of industrial diamond crud got loose and scored it.
Hacker- I'm just doing a simple rebuild if there is such a thing. I tore the engine down to correct a leak down issue and discovered that cylinder 1 was damaged. I sent the block out to get it repaired and Nikasil plated. Now cylinder 1 looks good but # 8 doesn't. I planned on using my stock pistons but UPS destroyed one of them and damaged 3 others in shipment so now I'm without pistons. To be honest I'm ready to throw in the towel. I've been working to get this car restored since 2001 and I keep running into problems like this. Mark Anderson can get me group 0 pistons for a good price but US NiCom refinished the block for the group 1 pistons that were in it and I can't afford to do it over again.
With the nicom plating, you can now safely use JE pistons, and you can have them made in any compression ratio you would like. Pistons, pins, rings and clips would run less than 950. Maybe even less than 900.
