928 Forum 1978-1995
Sponsored by: 928 Specialists
View Poll Results: Would you swap out a 2.73 R/P transmission for a 2.2 R/P one on a >400rwhp 928?
Yes, I think it would be worth it and the lower gears would suit the additional power better
57.14%
No, I don't think it would be worth it, plus it would inevitably make the car *seem* slower
42.86%
Voters: 21. You may not vote on this poll
Question for the >400rwhp club
Old 03-04-2008, 01:38 AM
  #31
jorj7
jorj7's Avatar
I switched my 2.54 to a 2.20 so I'd be able to hit 200 mph at ~5,750 rpm instead of 6,430 rpm
(also with a tire change). But I wouldn't do it with just 400 rwhp, I waited until I got over 500...
Old 03-04-2008, 01:55 AM
  #32
Andre Hedrick
Rest in Peace
Andre Hedrick's Avatar
Originally Posted by dprantl
Well I use my car as a daily driver. Sometimes I do not worry about gas mileage and drive her hard. Other times if I'm going 400 miles one way, it's nice to be able to get 24 - 25mpg. I'm not saying it's a big factor, just something to throw in to the discussion. Is it wrong to want a car that can "do it all"?
Dan
'91 928GT S/C
'86 928S 5-spd w/LSD *sale pending*
If you really want a 2.2 and you have a GT w/ LSD and NO PSD, we could work out a deal!
Old 03-04-2008, 06:46 AM
  #33
John Veninger
John Veninger's Avatar
you still get left with too short of a 5th gear
On what track?!
Old 03-04-2008, 09:03 AM
  #34
Vlocity
Vlocity's Avatar
The only reason I would consider changing my 2.72 LSD to a 2.2 would be if I was out of gear on the road courses I go to... and with the 3-4 tracks that I run on a regular basis the 2.72 is well suited. I have only one corner that I can think of at Putnam Park where I have to just feather the throttle (no time to shift up and shift back down) so for me the answer is no.....I am right in the meat of the power band and it helps to have the little shorter gearing to throttle steer the car.
If this was a daily driver then the answer might be different.
Regards,
Ken
Old 03-04-2008, 09:19 AM
  #35
Jim R.
Jim R.'s Avatar
Unless I was trying to break 200 mph, no way would I switch. 2.7x or 2.20, either way the wheels are going to spin above a certain power level. A more relaxed highway cruise would be nice, but I've done 1000+ miles in a day without difficulty. At the 400 rwhp level, it may make 1st gear more of a stomp on it WOT gear, but as you get the power levels up a bit higher, I don't think it will matter which gears you have. Your right foot will get a feel for how much throttle to feed in, or how much smoke to let out of the tires.
Anyway, wheelspin is not such a bad thing, it is kind of like the fuse that protects the halfshafts, torque tube, clutch..........
Jim
Old 03-04-2008, 09:26 AM
  #36
AO
Supercharged
AO's Avatar
I agree that keeping the tires as the weakest link is a good thing.
Old 03-04-2008, 09:55 AM
  #37
Vilhuer
Vilhuer's Avatar
There's the 87-88 reference again. Was there some sort of strength upgrade with those transmissions compared to the 85-86 ones?
Yes, input shaft bearing is 8mm larger in '87-95 gearbox. Also 1st and 2nd gear syncros are different IIRR. Really minor stuff but at 400+ hp they might make a difference on gearbox longevity. If this is most important point then GTS box is only stock option.
Old 03-04-2008, 09:57 AM
  #38
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,204 Likes on 1,243 Posts
85 was the switch to the better syncros.
Old 03-04-2008, 10:12 AM
  #39
Vilhuer
Vilhuer's Avatar
Thats right but all Borg Warner syncros are not equal. '85-86 boxes used one syncro design for all gears. Later boxes received different metal parts for most critical gears.
Old 03-04-2008, 11:29 AM
  #40
dprantl
dprantl's Avatar
Thanks guys, all this is great info. I guess I'll just wait a while and see if I get used to it. Right now I just can't seem to shake the feeling that when I'm in 5th, it's like I'm actually in 3rd, especially since the exhaust note of the '91 makes it seem like I'm in higher RPM than I actually am (not to mention the power). Damn I wish this GT box had an overdrive 6th speed geared to ~230mph.
Dan
'91 928GT S/C
Old 03-04-2008, 11:35 AM
  #41
hacker-pschorr
Dan,
If / when you dump the GT box for a 2.20.....I call dibs
Old 03-04-2008, 11:42 AM
  #42
Vilhuer
Vilhuer's Avatar
Maybe one day there is.
Old 03-04-2008, 02:30 PM
  #43
John Veninger
ok, what are you working on?!!
Old 03-04-2008, 02:59 PM
  #44
Vilhuer
Vilhuer's Avatar
Old 03-04-2008, 07:11 PM
  #45
mark kibort
mark kibort's Avatar
on the street and all tracks if you have a top speed of no more than 155mph
mk
On what track?!
Quick Reply: Question for the >400rwhp club
