S4 intake and cam cover materials
What is the material that the S4 intake is made from. Is it aluminum, or something else. why do they have the coating that seems to go after 10 years?
If aluminum, cant you just polish the metal and remove the coating to make it shiney like the early cars
same thing on the cam covers. are they the same materials? coating?
The reason i ask, is that my S4 intake is all aluminum, and i plan on carving it up when it comes off the car and maybe some polishing!
mk
mk
I believe the S4 intake is magnesium.
There's probably several 'cast' reasons why they chose this material perhaps one being longevity?
All I know is when the t.body and other parts are bolted up it weighs a considerable amount.
Your engine being a one off is perhaps why they chose aluminium; save a gram or 2.
Administrator - "Tyson"
Hey Mark, why not carve up a regular one before tearing up the one off?
I have one I will send you for the cost of shipping.
Todd has one he already started carving up, he was cutting out the internal horns.
That would be great!
Ill send you a p-mail.
Since this is a one off, and it is made from alumium, maybe i should just send it out to be extrude honed?
I think anderson sent his out to be extrude honed and didnt see much difference, but maybe with the mag. material, they couldnt get the material removed.
the outside would look interesting to see it all polished up. I dont think you can do that with mag. so, what is the coating on the mag for? are the valve covers the same material? im pretty sure, my covers are aluminum too. Now that would be cool if the covers could be polished to a mirror shine!
MK
MK
fwiw - the paint is a mass production tool as well. While painting will create a better presentation, it is also there to cover up the surface imperfections (pits, scars, etc). Saves having to finish each cast piece before final presentation, which is quite costly. You may notice that the factory paint was "top shot" for looks, with less than stellar coverage to the lower sides and bottom. Cost savings and looks sharp for a while. Nevertheless, you should be able to smooth out the trouble <cast> spots for a nice finish.
How do you tell the difference between magnesium and aluminum?
HP..........magnesium has only 2/3 rds the density of aluminium; now that I researched that (thx Hammer) its hard to understand why Porsche made the Alum. intake for the Holbert engine unless it truly was the proto.
Also, magnesium apparently reacts to water and hydrochloric acid and burns very hot; another reason to change those fuel lines.
Better question for Mark - how do you know it's aluminum? Porsche used magnesium for the 85/86 manifold.
Thats a good question. maybe it is magnesium.
it sure looks like aluminum, but i dont know for sure.
any quick scratch tests, besides the aluminum magnet
i can try?
MK
MK
The easiest test is to take a razor and shave a few tiny particles off it. then attempt to light those on fire if it is magnesium it will ignite, aluminum will not.
I HIGHLY doubt that your intake is aluminum though. But you should take a picture of it without paint on it and post it on the board. Preferably after the metal has been exposed to the eliments for so long.
