951 Piston Rings ??
Basic Sponsor
95mm rings are $132 a piston set x 8 = lots of money
Your best bet is to pick up a 4.7 liter lower end. Similar rings prices (to a 5.0)and much cheaper short blocks.
Its not that far off Erik. Find a 4.7L, find the bearings, find the rings (which are more expensive than the 951 rings as I recall), and cut the pistons if needed for the heads, and how far is that from a 5L?
You have to cut the pistons on an 85/86 with 16V heads, an S4 block will leave you with lower compression than stock.
All US 16V's use the same head - nothing to cut.
I've seen 4.7 liter engines sell for under $1,000 (short blocks much less). I'm not sure where you can find a 5.0 of any year that cheap.
Basic Sponsor
I now stock 951 piston rings for $228 a set of 8.
Chrome face, correct bevel and spring - a real must for the boost club.
Form an orderly queue please 8>)
