928 Forum 1978-1995
Sponsored by: 928 Specialists
Blower motor problem
Old Feb 23, 2008 | 10:20 PM
6mil928's Avatar
6mil928
From: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Default Blower motor problem
Well finally got my car back from the body shop this week. Started installing the new parts I got from Roger earlier this week. When I bought the car it had a bad blower motor and resistor pack. I got a used blower from Stan and a new resistor pack from Roger. Before changing the resistor pack I plugged the blower motor in and it only ran on high setting. I then changed the resistor pack and the blower motor runs on high no matter what the setting in the car. Anyone have any idea on how to go about trouble shooting this problem? Thanks, Jason
Old Feb 24, 2008 | 12:09 AM
6mil928's Avatar
6mil928
Old Feb 24, 2008 | 12:24 AM
LT Texan's Avatar
LT Texan
That's a quick bump.
If the resistor pack is the switch, I think I'd take a multimeter to it. Sounds like a short at the switch.
Old Feb 24, 2008 | 12:34 AM
6mil928's Avatar
6mil928
Sorry for the quick bump. I'm wanting to get this thing back together this weekend and it's too late to be calling roger on it. Happen to know which wire I should be checking with the ohm meter. Guess I could pull out the wiring diagram.
Old Feb 24, 2008 | 08:55 AM
Landseer's Avatar
Landseer
Was the resistor pack an direct fit or is some wire-reversing necessary? There was some talk about having to adapt the available late resistor packs to earlier cars.
Old Feb 24, 2008 | 09:24 AM
6mil928's Avatar
6mil928
Never heard of this but it might make sense. Anybody have any info on this???
Old Feb 24, 2008 | 09:26 AM
Rod Underwood's Avatar
Rod Underwood
I was "under the impression" that they're were no longer new "old model" resistor packs available, only used versions. That may be your problem. Someone who is more electronically gifted than I am may be able to tell you how a new one could be used in an older application - if you can verify that impression.
I know this isn't much help, but there's a chance it's the problem.
Good luck and keep us posted.
Rod
Old Feb 24, 2008 | 09:47 AM
Landseer's Avatar
Landseer
https://rennlist.com/forums/showthre...resistor+pack#
Here's one of the places I saw the reference to new and old resistor packs. Its not real clear which version he ended-up installing, but the mention of NLA/ superceding caught me I. Hope somebody else chimes-in on this who's been there. I have a similar problem also, and am ready to dig in today.
Old Feb 24, 2008 | 10:08 AM
Dennis Wilson's Avatar
Dennis Wilson
Is your heater set to defrost? If so, that relay may be activating it.
Dennis
Old Feb 24, 2008 | 11:01 AM
Leon Speed's Avatar
Leon Speed
Running on high on whatever setting indicates that the bi-metal safety switch in the resistor pack stays closed. Can you tweak the switch to open and see if that solves the problem?
Old Feb 24, 2008 | 03:08 PM
Alan's Avatar
Alan
Electron Wrangler
Only the old model had this protection device. Newer style disables the blower when it overheats.
Its most likely a connection problem if you are connecting a new style resistor pack on a car originally configured for an old style resistor pack.
The new style pack is actually a better design but has a slightly different connector assignment. You can swap the pins in the car side connector to make it work correctly.
You need to remove the existing connection to Pin 8 it is no longer needed then swap the existing pin 6 connection to pin 8 - it should work normally.
Alan
Old Feb 24, 2008 | 05:40 PM
6mil928's Avatar
6mil928
Alan
Alan have I told you that I love you lately When it comes to electrical your the man I'll be on my way home shortly and I'll give it a shot. I'll post on it so everyone knows how it went. Jason
Old Feb 24, 2008 | 10:37 PM
6mil928's Avatar
6mil928
Ok guys once again the list saved the day. This list is worth it's weight in Gold. A very special thanks to Roger and Alan. Alan's idea worked like a champ. It will be so nice having a blower that works. I will have to clean out the leaves and debris and vacume off the heater core before I get it all installed. I do have 1 question though. What was pin 8 originally for? Jason
