Any info on the new Eaton TVS supercharger on a 928?
I see 75% on the largest whipple blower and 80% on their smallest 1.3L blower.
YOU ARE LOOKING AT THE NAME OF THE UNIT, NOT THE SIZE.
If the lysholm charts are out of date then what info are you working off of?
Bill
But the numbers are clear as day. If they are misleading numbers well then thats another story, but 80% is higher then 75% i learned that in like 11th grade
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I don't care about a 1.3. You are the one saying they list efficency of a 1.3 their site. They do not. They List a 2.3l, 3.3l and 5.0l models.
They may make a kit for a pt cruiser but I don't care about that.
I want to see charts for all positive displacement superchargers from 1.7l to 2.5l as those would be best for a 928.
Ryan, I'm sorry but you are not providing good or even acurate information.
LOOK AT THE SITE
you want between 1.7 and 2.5, ok well they list the 2.3L unit (which is what i would use on my 5.0L) and it clearly says AE is 80%!
Game over!
Game over!
Under the Lift
We did briefly note the new blower in a ZR-1 thread. We don't need to get hung up about Gen 4 or 5 or whatever it is... It's new and a greatly optimized Roots. It looks a lot better than what I have, so I would try it if I could find one at a reasonable price (maybe the boneyard will start to see them soon). New Gen 5 are inexpensive and used ones in good shape are DIRT cheap. The charts and specs argue that the TVS is up there with Autorotor, but I'm not so sure.
i am checking out of this thread
Now does anyone have any real information? Links to actual charts of the sizes and types of superchargers mentioned would be appreciated.
Bill
The system thats going into the ZR1 has an integral manifold.
So what that tells me is that the housing is cast into the manifold so using one from a crashed ZR1 10 years down the road wont help you. I believe the caddy will use the same manifold. A cast part with the housing integral to the manifold and the rotors and intercooler cores added after machining. This would not be plug and play.
A new unit out of the box may work. If not you could possibly change the manifold you have to accept the new (if different) mounting locations of the new blower.
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
1 Post
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
You know I'm a glutten for punishment though - I'm adding a '81 944 to the stable too
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Under the Lift
you could make anything thats flat fit. IIRC your manifold is pretty flat. So even worst case scenario you make a spacer/adapter to get it to mount.
But you cant use a take off from a ZR1 or CTS-V, those are totally different. Those should bolt onto LS1,2,3 6 and 7's though!
I was looking for the Autorotor charts and found this information on the site of Opcon, the company that manufactures and distributes the Autorotor and Lysholm (brand) twin-screws. It appears that they have closed the US business unit and the site that thye direct to for business after july 1 2007, www.lysholm.se, is not in service. I wonder if they are still selling the autorotors? I'll try emailing them.
http://www.opcon.se/index.asp?sPage=1&langID=2&cID=17
"May 1, 2007
Dear Valued Customer:
In December 2005, we began the implementation of a plan to streamline several of the business units within the Opcon AB family. The move of the Opcon Incorporated office to Michigan has been successful and we were able to offset price increases for many of our aftermarket products. Unfortunately, the American automotive business climate continues to deteriorate. In February 2007, the Opcon AB Board of Directors elected to initiate another phase of change resulting in the decision to close Opcon Incorporated effective July 1, 2007.
Please forward all inquires, purchase orders and Request for Quotes (RFQ) to the appropriate subsidiary contact listed below:
Lysholm Technologies AB, Sweden
www.lysholm.se
Product: Lysholm and OA-Style Compressors, Extensions, Pulleys & Support Components"
"May 1, 2007
www.lysholm.se
