Engine Refurbish - Boost Prep
I started this thread to let people now what I'm doing in case I need some help on issues as I go along.
I bought the car two years ago. It's an 89S4 ROW, A/T I bought from a guy who imported it from Japan with no history. It currently only has 40k kms and is in pretty good shape. Although it has low kms it's still going on 19 years old. I've done a fair bit of work to date. Eihbach/bilstein, 18" wheels, Stero etc. but my last major goal is to add some boost this summer. However before I get there I wanted to make sure the engine was in top shape first. I started writing down things I needed to do and when I finished my list I thought it might be easier just to pull the engine to do all the work. I'll keep you posted on what I'm doing as I move along.
I read the WSM about removing the engine and followed every step from 1 to 49, pages 10-12 to 10-20. I figured the factory did it so many times they must have come up with the best method. It was relatively easy, it just took some time. I worked through these steps in a couple of evenings.
Last sunday morning Colin (aka Lizard931) came over to my place to lend a hand as he's pulled 4 maybe 5 engines now and I thought I could use his expertise. Everything was unhooked and ready to go but as soon as we got started, the hoist didn't work? Not enough fluid in the unit. After spending about 45 minutes fixing the hoist we were ready to go.
![Name: 1 Pre Hoist.jpg
Size: 121.8 KB](https://rennlist.com/forums/attachments/928-forum/255937d1203354283-engine-refurbish-boost-prep-1-pre-hoist.jpg)
I looked at the time stamp on the pics and we had the engine out in 15 minutes. We were having a little trouble at first seperating from the bell housing but the WSM says to tilt the engine forward first so we put a floor jack under the starter motor first putting a little upward pressure which tilted the engine forward then as we lifted it came right out with the help of my neighbor Ron manning the hoist with Colin and I wiggling it out.
![Name: 2 Hoisting.jpg
Size: 130.1 KB](https://rennlist.com/forums/attachments/928-forum/255938d1203354375-engine-refurbish-boost-prep-2-hoisting.jpg)
Once the engine was out we had a pic with our big catch! A 600 pounder!
![Name: 3 Engine Out.jpg
Size: 127.2 KB](https://rennlist.com/forums/attachments/928-forum/255939d1203354385-engine-refurbish-boost-prep-3-engine-out.jpg)
My wife gave me the groovy jump suit for Xmas. How do you like the printing on the back! My neighbor Ron is our apprentice. He thinks we're nuts pulling this thing out. He was having so much fun we gave him a wrench and he stayed all day helping out.
![Name: 4 Engine Inspection.jpg
Size: 138.0 KB](https://rennlist.com/forums/attachments/928-forum/255940d1203354434-engine-refurbish-boost-prep-4-engine-inspection.jpg)
A quick look around showed that the frost plugs on the end of each cylinder head had been leaking. I couldn't figure out where it was coming from with the engine in the car.
![Name: 5 Coolant Leak.jpg
Size: 139.2 KB](https://rennlist.com/forums/attachments/928-forum/255945d1203355505-engine-refurbish-boost-prep-5-coolant-leak.jpg)
When we pulled the coolant plugs from the side of the block nothing came out? The opening was plugged solid. If you look closely you can see the result of a PO or mechanic adding stop leak to the block. Cheaper than pulling the engine to replace the frost plugs properly I guess. Don't use stop leak!
![Name: 6 Stop Leak Result.jpg
Size: 112.3 KB](https://rennlist.com/forums/attachments/928-forum/255946d1203355664-engine-refurbish-boost-prep-6-stop-leak-result.jpg)
The engine tear down begins!
I wanted to get this post going as I'm sure I will have many questions as I progress. My goal is to get it down to the block but not as far as splitting the crankcase and begin working my way back up.
It looks like I can only post so many pics at a time so I'll have to move on to the next post.
Comments, suggestions, etc. are welcome but I thought it would be fun to post a diary of my new project! I've bagged and tagged almost everyting that I've taken off but I'm sure I'll need some help from you guys putting it back together....
Having fun so far!
Brent
Having fun so far!
Brent
Awesome! Now strip her down!
Now that we got it on the stand the three of us started taking things apart.
![Name: 8 Tear Down Begins.jpg
Size: 115.2 KB](https://rennlist.com/forums/attachments/928-forum/255949d1203357749-engine-refurbish-boost-prep-8-tear-down-begins.jpg)
You can see the residue in the cooling system from the dreaded stop leak!
![Name: 9 WP Stop Leak Residue.jpg
Size: 145.0 KB](https://rennlist.com/forums/attachments/928-forum/255950d1203357834-engine-refurbish-boost-prep-9-wp-stop-leak-residue.jpg)
Now we're humming along getting the valve covers off. how can you tell Colin loves this stuff!
![Name: 10 Valave Covers Off.jpg
Size: 127.6 KB](https://rennlist.com/forums/attachments/928-forum/255952d1203357885-engine-refurbish-boost-prep-10-valave-covers-off.jpg)
More coolant crap at the rear access ports.
![Name: 11 More Coolant Crap.jpg
Size: 123.1 KB](https://rennlist.com/forums/attachments/928-forum/255953d1203357980-engine-refurbish-boost-prep-11-more-coolant-crap.jpg)
My neighbor Ron was fascinated by all this. He didn't want to go home.
![Name: 12 - Ron Fascinated.jpg
Size: 134.8 KB](https://rennlist.com/forums/attachments/928-forum/255954d1203358058-engine-refurbish-boost-prep-12-ron-fascinated.jpg)
This is the work we got done from the time we began the engine pull at 10am to this point by 2pm. Four hours to get this much done, I was impressed with me and my helpers!
![Name: 13 End of Day 1 4 Hours Later.jpg
Size: 125.3 KB](https://rennlist.com/forums/attachments/928-forum/255955d1203358261-engine-refurbish-boost-prep-13-end-of-day-1-4-hours-later.jpg)
Time to start organizing the mess. I had some shelving where I eventually put all the parts according to their groups but I laid everything out first. It's now 4pm after cleaning up. Name these parts? Not now, time for a beer!
![Name: 14 Name these Parts.jpg
Size: 101.6 KB](https://rennlist.com/forums/attachments/928-forum/255956d1203358517-engine-refurbish-boost-prep-14-name-these-parts.jpg)
My next post I'll have some pics of the camshafts and heads coming out!
Brent
Brent
Very cool
From the looks of what youve found so far i think its a good idea to go through the engine. That leak looked like a real mess.
By the leak there in the pic i can tell thats the drivers side head but what is that pipe for that goes under the headers? Is that some type of air injection system that goes directly into each header pipe? That is not on my US car.
You are correct. The pipe running below the header is the air injection system. There are two types. One blows air into the Cat and the other blows it directly into the exhaust port. This is the one I have. As I mentioned, my car is a ROW version which would be different than a US model. Check your PET Catalog up to MY 91 and you'll see both versions.
I'm going to be removing my air injection system altogether and plug the holes with the appropriate bolts. The current ones holding the pipe in place look like banjo bolts but not sure on the size?
cool pics. Ive done this a bunch of times on the older buggers, but not the S4. how was it pulling the harness out of the firewall? Im thinking with mine, being a race car, there is not much under the dash, so its easy toget to stuff underthere, like pushing the wiring out the hole.
any thoughs about disconnecting things while the engine was in the car and leave the harness in?
There was some debate on which was easier.
mk
mk
mk
mk
I am a big advocate for leaving the harness in as are some others.
Jim,
Thx for the part # I'll make a note and give you guys a call. I find it pretty hard up here to find a lot of these metric bolts.
Mark,
The WSM says to feed the harness through the firewall as you're lifting the engine. However, the night I was finishing disconnecting everything Colin came by to help with the last few things. While I was under the car disconnecting the starter, alternator, ps hose by the time I surfaced, about 20 minutes, Colin had already pulled the whole harness out and it was sitting on the manifold! You might want to ask Colin how he did it as I wasn't watching but I think it's much easier to pull the engine with the harness hooked up to the engine side.
Mark,
Here's what we did with the camshafts. Before we pulled them off we painted the sprocket and chain in the installed position so we don't need the fancy camshaft tool to reinstall. Notice the silver paint. I'll be keeping them in the boxes until they are ready to go back in.
![Name: 15 Camshafts.jpg
Size: 112.7 KB](https://rennlist.com/forums/attachments/928-forum/255982d1203369693-engine-refurbish-boost-prep-15-camshafts.jpg)
Here's the dirty block with some green coolant that was coming down from the 1-4 cylinder head front frost plug.
![Name: 16 Dirty Block.jpg
Size: 124.2 KB](https://rennlist.com/forums/attachments/928-forum/255983d1203369761-engine-refurbish-boost-prep-16-dirty-block.jpg)
The top of the pistons had some nice carbon deposits but they were pretty soft and could easily be scraped with a screwdriver. Any ideas on how to clean and buff these up? Note that before I pulled the engine I did a compression and leakdown test to see how things were. The compression readings were close to 185psi all around and the leakdown numbers were from 3-8% in all cylinders. so I think the rings and valves are in pretty good shape.
![Name: 17 Pistons.jpg
Size: 141.7 KB](https://rennlist.com/forums/attachments/928-forum/255984d1203370022-engine-refurbish-boost-prep-17-pistons.jpg)
The valve covers are pretty greasy. I'm planning on powdercoating the intake and valve covers wrinkle black with red lettering. Looks pretty cool! You can see in the background my great organizational method for the hydraulic lifters. Egg cartons! Labelled according to which cylinder head, cylinder and which ones are intake and exhaust valve. Should make it easy to put them back where they belong.
![Name: 19 Valve Covers.jpg
Size: 126.4 KB](https://rennlist.com/forums/attachments/928-forum/255985d1203370187-engine-refurbish-boost-prep-19-valve-covers.jpg)
I removed the 2/6 bearings to see what shape they were in. The pics show the inside and outside. Looks to be a little wear. I took some plastigauge and the radial play measured 0.038mm. Seems about in the middle of the wear limit. I'm thinking that now that I've gone this far I may as well replace the conrod bearings.
![Name: 21 26 Bearing.jpg
Size: 87.1 KB](https://rennlist.com/forums/attachments/928-forum/255986d1203370544-engine-refurbish-boost-prep-21-26-bearing.jpg)
![Name: 22 26 Bearing Inside.jpg
Size: 120.8 KB](https://rennlist.com/forums/attachments/928-forum/255987d1203370588-engine-refurbish-boost-prep-22-26-bearing-inside.jpg)
Gotta go. heading off to get a quote on having the intake and valve covers stripped.
More later.
More later.
