928 connecting rods
I was digging around in my parts and thought I'd compare con rods from different 928 engines.
below is a pic of two rods. one from a US spec 4.5L, the other from a 5.0L.
I was surprised in the differences.
the 4.5 rod is beefier, with nice thick I-beams.
the 5.0 rod looks like something home-made, not very heavy duty, and lousy castings on the sides of the beams.
weights for the rods are about the same, although I do not have a good set of scales to compare.
both rods have the same pin/ bearing diameters and hole to hole lengths, so one might make the assumption that the 4.5 rod maybe a better rod......?
Comments?????
Check it out.......
--Russ
Comments?????
Check it out.......
--Russ
The rod on the right has a sharper bend at the base of the rod next to the bolt head. Stress point ? Rod on the left is beefier top and bottom at those spots by the bolts. Looks to be a substancial increase.
The rods after 88 were like the one on the left. The right side is more like all prior.
I had no clue about the rods, so has anyone had any experience with the question of:
Which is better?
I'm curious if there are any appreciable differences......
thanks--
--Russ
Which is better?
thanks--
--Russ
Some early 928 rods are considered "forged" though people speak of "powder forged" which seems better than the cast ones that came out of my 89 motor. So I put in rods that were more like the forged ones and used ARP rod bolts.
there are a couple of variations of the type on the right as well. we put scots engine together with a mix of both. all balanced tip and tail. the main difference was the thicknss of the rod at the wrist pin hole. I think a search can find the pics.
mk
mk
Comments?????
Check it out.......
--Russ
Comments?????
Check it out.......
--Russ
