Bill Ball VS. The Fuel Pump
Under the Lift
What seems to be at the bottom of most 928 tanks is just dirt, and sometimes an awful lot of it. Of course, my tank was spotless when I opened it up at about 150K miles to check the in-tank pump, which was completely in-tact as well. My car is blessed.
Team Owner
when you get your new pump it has a waring about replacing the in tank filter screen for the warranty to be valid, of course this means unscrewing the big nut on the tank outlet and this can then start a leak of its own. So possible you can can inspect the intank screen from above?
cleaning the tank is always a good idea on a 20+ year old car...BUT with the known weakness of the 928's gas tank at the 2nd pump or "strainer" it is a risky proposition....when my fuel pump died (on a full tank no less) I thought about changing the strainer since I don't have an in tank pump....but a knowledgeable 928er talked me out of it unless I wanted to spill all the gas and buy a new tank......
Originally Posted by MrMerlin
...possibly you can can inspect the intank screen from above?
Thanks Stan. Guess I should order the sending unit also, and avoid running out of gas again.
Team Owner
Knowing you have plenty of gas in your tank is a beautiful thing, beats trying to guess how many miles you might have driven, you didnt mention the fouled up level reading.
So does the low fuel light come on? This is the your secondary low fuel warning, if neither one is working then it might be something other than the sender, you might check the top of the tank sender connections
The PO had mentioned that the guage was not reliable. But no further detail, although he also mentioned the fuel filter had just been changed.
Team Owner
it might be a good idea to check for a pinched vent hose,
