what's this? Driver side Box identification
it looks pretty serious, like something that keeps the engine running or something
Mk
thanks. I guess its not going anywhere, as i do leave the ABS on, most of the time.
mk
i have so little rear brake bias, that i still have the same set of rear pads from 2 seasons ago. and before that, i was using mintex street pads in the rears for 4 seasons prior. they do get warm, so i know they are working, but its all on the fronts.
as a side note about trail braking and getting the car bent out of shape, there was a race or two where i didnt get the idle cut off switch removed. in those cases, a real hot engine, after a slow gear downshift , the engine would die in the middle of a shift, and when the clutch was released, the wheels would be urged to lock a bit, and would toss the car sideways, but that was an extreme case. Ive trail braked other cars, like the BMW M3 the same way. Trail braking, like what is done in turn 2 at laguna, is only to go much deeper than going straight, and start a gentle turn in while still under braking, but not quite as hard at that point. (with a goal to urge rotation in some cases) . by the time . Here is a key point. If done right, you have put the car in a lower gear that is reving down under threashold braking. even if you trail brake, the rear brakes are being driven by the engine and dont have much of an effect.
I have never seen any lockup of the fronts or the rears without abs in this region of the turn. Instictively, i think most would take a little pressure off the brakes as they are shifting the weight of the car. more of a factor is how you toss the car around under braking and even just on the initial turn in. after my mishap at turn 9 at laguna in my old car, there is not one single turn in that i dont expect that rear end to come around when i am pushing hard, abs or not. our abs is so weak, and scan times are so long that when its engaged, it almost feels as though i am driving on snow. what is nice about it, is that the sound warns you to modulate, rather than the sliding feel or smell of a lock up.
Scot is doing the same type of technique with the 82 5 liter, and has never had a rear lock and disturb the car. he is down to a 1:41.4 right now, which is scooting right along.
mk
edit: added some additional points
either by accident if the engine RPM is too low throttle closed or intentionally with a bit of BWHAA ! Tight slow corners the front tires are working far more than the rears so there is some extra traction that can be used to accelerate ....The act of turning must use some of the stored energy to redirect the mass of the car so anytime you are turning the car is slowing down unless you are on the gas. I often have a student run onto the skid pad at good speed and tell them to NOT TOUCH the brakes just coast out of gear and make a series of quick left right turns just to show them how much the car will slow down. Try to teach them that if they are not HARD on the brakes they need to be on the gas ! Then I make them ride with me and I am on the brake and the gas at the same time with my size 14 , downshifting in corners all the things you do not want them to try just yet... Since I run the same size tire front and rear I have under hard braking going down hill transfered enough weight to the front end that the rear tires would chirp but that is unusual.
part of the way i got around tiny brakes is doing what you talk about below. i go to the limit of the brakes (and the room i have to slow) and then no matter where i am, i start a turn in, the turn in is a more powerful brake than most people understand. you might have to wait a bit to get to the speed safe enough to start applying the gas, but until that happens, the fronts are taking a beating.
anyway, my use or not use of ABS doesnt effect much. I think the only time you can just stomp on the pedal and and use the ABS for an advantage is with real racing ABS like on a cup car. our 928 abs is 20 years old, and is only good either in the rain or as a safety net (warning device) in racing to stop a flat spot and tell you that you have just exceeded the tires capability to stop effectively so " get off the brakes quickly and try again
)mk
