928 Forum 1978-1995
Sponsored by: 928 Specialists
Racing 928 flywheel
Old Feb 1, 2008 | 10:34 AM
John Veninger's Avatar
John Veninger
Thumbs up Racing 928 flywheel
This is such a work of art! Only 12.5lbs!!
No more slipping or broken clutch for me in the future
Before it starts.... Yes, it is an expensive, highly custom, race part for the 928.
Just a shame that it will be hidden inside the car!
Old Feb 1, 2008 | 10:36 AM
Rick Carter's Avatar
Rick Carter
That is gorgeous.
Old Feb 1, 2008 | 11:04 AM
FlyingDog's Avatar
FlyingDog
Group buy! oh wait, this isn't the 944 forum...
That looks great. When will it and the motor be on a track?
Old Feb 1, 2008 | 11:17 AM
BC's Avatar
BC
Thats for which year? Looks like s4. Who made that?
Old Feb 1, 2008 | 11:21 AM
Fabio421's Avatar
Fabio421
Man of many SIGs
Very nice looking. Is this a one off item or is it the one Carl was offering a month or so ago?
Old Feb 1, 2008 | 12:02 PM
MGW-Fla's Avatar
MGW-Fla
Well John, you could get a spare one & use it as a clock or something just so you could look at it; then you'd have it just in case you ever needed a backup too!
Get that car back on the track soon, you need to be racing again son!!
ps, thanks for your time & help the other week! I'll let you know once I have things resolved!
and at least my guess was the same as your diagnosis. I just wasn't confident to know that!
I know, I know....
Old Feb 1, 2008 | 01:26 PM
mark kibort's Avatar
mark kibort
what does a stock flywheel weigh again?
what a work of art!
But, how is going to stop a slipping clutch? get rid of heat faster?
curious what the motivation was to make such a special part.
mk
Old Feb 1, 2008 | 01:39 PM
V8 Man's Avatar
V8 Man
11,5 lbs (78-82 with no timing gear)
Old Feb 1, 2008 | 01:42 PM
BC's Avatar
BC
Originally Posted by Sterling
that doesnt look like Carls part... probably something for a tilton dry clutch
I think you are correct, because the starter ring attaches differently on the S4 system.
Old Feb 1, 2008 | 01:57 PM
RyanPerrella's Avatar
RyanPerrella
it looks like an s4 type flywheel with a built in starter ring which on the s4 is on the Pressure plate, its not mounted on the flywheel. I was going to say what pressure plate are you going to use now but the tilton seems to be it. The diameter of the clutch contact area is tiny. Most likely a multi plate setup.
cool
Old Feb 1, 2008 | 01:58 PM
RyanPerrella
Jim B, is this similiar to the setup you guys were thinking of offering and which you mentioned in a thread about lighter pressure plates that i posted on?
Old Feb 1, 2008 | 02:36 PM
mark kibort
so, this new aluminum flwheel is heavier! maybe with the timing ring, its the same. in the end, is the dual disc stock 928 clutch that much heavier overall. I know the clutch parts for the tildon are very small and probably half the weight of the stock dual disc clutch. However, the dual disc set up is not that bad. i think i measured 25lbs vs 40+ for the Stock S4.
Mk
Old Feb 1, 2008 | 02:47 PM
John Veninger
Total weight, 22.5lbs and can hold no matter how much torque my stroker puts out!
Old Feb 1, 2008 | 02:49 PM
BC's Avatar
BC
More info please John. Price, cool specs, how is it installed.
John Veninger
to transmit 500+ ft/lbs of torque....................and to win races
