Anyone in PA NJ or DELAWARE have the PORKEN TIMING SETUP?
From: Philadelphia, PA , USA The Great Fighting City of Brotherly Love
Anyone near philly have the timing setup I could use for an hour?
Earl Gillstrom in Glen Mills, PA (and I, as partner in this tool) has the setup. He'll do the timing for a reasonable fee, but it's not available for loan. He is unavailable for about 2 weeks.
captearlg@gmail.com is his e-mail address.
Gary Knox
West Chester, PA
Gary Knox
West Chester, PA
Craic Head
Earl Gillstrom in Glen Mills (and I, as partner in this tool) has the setup. He'll do the timing for a reasonable fee, but it's not available for loan. He is unavailable for about 2 weeks.
Gary Knox
West Chester, PA
Gary Knox
West Chester, PA
Chronic Tool Dropper
Earl is a retired guy who will work on your car for a very reasonable rate. Every feedback from folks who have visited him has been stellar. You can do your work under his supervision, work with him if you want to help-and-learn, or do a watch-and-learn session with him. He's meticulous, to say the least. Take a look at his $50 GT and you'll get the idea. Plan on getting your wheel alignment done while you are there. Better than a commercial alignment, and will pay you back in extended tire life immediately. You won't meet a nicer guy.
I've never been so thrilled to work on a machine...I don't want to pay someone else...It's my play time! Nobody in our region has a porken timing rig? I can have my covers off in 25 minutes, and be done the whole deal in 2 hours...tops.
Need someone to come to the rescue!
Thing is, I have a flat spot between 3000 and 4000 rpm, and it was much more dramatic when I had set the cams all the way advance. Now that I have them in the middle near the wear marks...and it runs much better, but still a flat spot. Before I go chasing every freaking thing on the board, I want to make sure the cams are as close to sync as possible.
My plug wires are old and crusty (have another set in better shape) but I didn't see any blue sparks in the dark even with water mist technique, My maf is suspect (I have another known to be fine- I will test this weekend), I have 2 spare coils known to pull hard- also will try this weekend.... I will make another post on monday about this issue if none of these items clear things up...
The symptom is- full pull to 3000, then a slight lag to 4000, then pulls hard to redline with just a slight hint of occasional hesitation (almost impossible to detect, but I know what full on juice is supposed to be, so I can sniff it)....If I bang gears and keep it in the hot zone, it runs like a race car....Time after time, I can punish the **** out of it.
New fuel filter, oil chnge, air filer, wp, tb, front seals, and new bosch platinums..... within last 150 miles. I checked the octane loops, they are not connected...I unplugged the TPS, it made a change in idle so I assume it's ok. I have not changed any o2 sensor....does anyone suggest that I replace them [are there 2?] I noticed when I took out the spark plugs that were in the car when I got it that they looked very lean to me... After reading the posts on these matters, I presume the MAF is going to straighten me right out....I'll make a post as soon as I swap it out with the other one. Man, it really helps to have 2 of the same model year... without it I can't imagine chasing down gremlins on a tight budget like mine!
