928 Forum 1978-1995
Sponsored by: 928 Specialists
Keyless entry kit install questions
Old Apr 10, 2002 | 10:05 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Post Keyless entry kit install questions
I bought a fairly simple keyless entry kit - Audiovox APS-45. It flashes lights and sounds horn and can roll up the windows, but I'm most interested in just locking and unlocking the doors (and rear hatch separately) with the 2-button remote. The kit provide both negative (ground) and positive low current pulses for the door lock. I understand the 928 is negative, possibly both for lock and unlock. Before I try to decipher the wiring diagram, if anybody has BTDT, clue me into the door lock operation and any other wiring tips for a kit like this. I can't find anyone that has documented an installation on the web. So, I will do so once I understand the wiring.
TIA,
Bill
89 S4
Old Apr 10, 2002 | 11:44 PM
Alan's Avatar
Alan
Electron Wrangler
Post
Bill,
Negative for lock & unlock and you shouldn't need any relays if your kit has negative O/P's. Best bet is probably to locate it next to the factory alarm module - location varies* - since all the required connections are there already (well except for the hatch release if you were going to do that).
* On the earlier cars it was in the console, later it was up in the dash & under the passenger seat. On yours it should be split between in the console & behind the glove box (according to the manuals). You can access the wires you need and probably locate your new module in the console.
It should be a small module w/ 9 pin connector w/ 8 wires attached. Its the only place in the consolewith the Brown/Green & Brown/Red wires below:
The wires you need:
Brown w/Green stripe = Open/Disarm
Brown w/Red stripe = Close/Arm
Brown = Permanent Ground
Red = Unswitched 12V (Battery via fuse)
If you need to access the unlock drive for the rear hatch you will have to route it across from the switch (yellow wire) needs a positive O/P, goes to existing relay. Looks like on your year the hatch setup (lock & alarm interface) is different than on my GTS so hard for me to say how to set this up. But if you have a 2 stage unlock (push button twice to get a 2nd unlock channel pulse) you should be able to use this with the rear hatch drive directly (since the alarm will already be disarmed) HTH
Alan
Old Apr 10, 2002 | 11:47 PM
Normy's Avatar
Normy
Cool
Bill-
A contact that I've chatted with is "AaronNOrlando@aol.com", who told me he has wiring diagrams and has installed alarms on Porsche 928's...
Normy!
Old Apr 11, 2002 | 03:02 AM
Bill Ball's Avatar
Bill Ball
Under the Lift
Post
[QUOTE]Originally posted by Alan Moore:
[QB]Bill,
So you mean these wires aren't just status pickups for the alarm by will trigger the lock and unlock of the doors? Great!
Bill
89 S4
Old Apr 11, 2002 | 10:58 AM
Alan's Avatar
Alan
Electron Wrangler
Post
Bill,
Yes they do both door lock/unlock function & alarm arm/disarm functions on a single wire. This makes life easy doesn't it (for once..)
Alan
