89S4 transmission grenaded - need replacement
Sounds like I broke a gear in my transmission while making passes at the drag strip. Shifted into second and had nothing but grinding. Before I rip everything apart, I thought I would check to see if anyone has a spare for sale.
I have an 89S4 5sp limited slip (or should I say had, it is very limited now).
At least I was consistant; 12.3, 12.2, 12.2, 15 minutes with a tow.
Thanks in advance,
Woody
Thanks in advance,
Woody
If its truly broken, and you will be buying a space, I will offer now to buy the broke unit for shipping and a couple hundred, if thats okay with your plans.
But all at once. I am still mentally fighting any parting of the car. I may just have a good couple quarters and have to get it back from him.
There are transmissions around for good prices...but the 89S4 5 speed is the rarest of them all with the 2.64 rear end.....everything else is either 2.20 or 2.72....
Rest in Peace
...in the US. It's the same 87-89 for Euro/ROW.If so, it can be swapped into any 87-89 and maybe 85-86, but gearing would be different (lower). I'm pretty sure pinion machining would be required to fit it in an 83-84 Euro/ROW tranny, but gear ratios would be the same as you have now.
