Unable to fully tighten bolts completely on MB
Rest in Peace
I can add a larger bolt if needed such as a Sae but before I do anything I want to hook it up and see that it will torque to specs. Still can not find the torque settings for the mounting bracket. I will try this first I may not have an issue, just remember this from before but not completely sure, but want to test it first.
928 Engine Re-Re-Rebuild Specialist
Administrator - "Tyson"
Craic Head
I'm with HP and Mike on this one - replace the water pump with new (and make sure the TB pulley is on the shaft good and tight). The boss on the water pump where the S/C bracket bolts on is raised (closer to the radiator) and clearance to drill and tap straight in may be very tight.
If you must leave the water pump on, then TimeSerts is the way to go.
Adam
Adam
Stop spending my money I have 500 miles on this pump
There is enough room it's the top one, I did a test fit and the other two torqued to 20 ft pounds, so I need to just use one for the repair. Looks like Timesert or nutsert or whatever will work fine, "should for the money". I'm going to get a right angle adapter for my drill just in case. From what I read Helli coils are not very reliable in the long run. I try not to get to excited about these set backs "don't need another Heart Attack" over some thing like this. Pictures will be provided on my other post A.S.A.P.
Thanks for the help I think
Captain Obvious
Super User
Super User
Actually its $265 if you include the cost of the insert kit. I don't see the logic behind not just drilling and tapping it up to the next size. You'll have to do drill it to get the insert in there anyways. But this is jsut my oppinion, nothing more.
Captain Obvious
Super User
Super User
