If your in the market for a $10,000 928 S engine, i know a deal
Yeah i was doing the math myself when i was out running errands just awhile ago, I figured at 30mph average which is what my display tells me, thats still 15,000 miles. Its so odd you would quote an engines use in hours run. I wonder if we asked him how many rpm's its done if he would have an answer.
hours is so vague. You see Rpm's on trucks and hours on equipment, like brush chippers. Odd
Anyway, I thought it was comical, glad i'm not the only one
Christian
Under the Lift
Did this shot puzzle anyone else? How did the entire motor/crossmember assembly with steering rack still attached get on the ground?
Fleet of Foot
Under the Lift
Fleet of Foot
Actually if you look at some of the side view pic's, the crossmember appears to be intact. They probably removed the engine from beneath the car. Probably a good thing as it hides the apparently broken mount boss to the uneducated eye.
Under the Lift
I guess were wasting more time than called for on this engine. So they had the car on a 2-post lift, detached the front crossmember and raised the body off it. No problem.
Has anyone ever contacted sellers like this and called them on the BS? I have done that a few times when I see an ad that has info that is blatantly wrong, or the seller (such this one seems to be) has either a: erred in valuation, or b: is out to rip off some poor blighted soul; either way, they are deserving of any insults delivered directly.....ignorance or thievery both deserve punishment.
K
K
Under the Lift
I don't think this guy would respond well to such inquiries. Just the way the ad was written threw me for a loop, leaving alone any factual issues. Honest or dishonest mistakes are worth noting to the seller, but this one seems just too far out there to be called a mistake.
