928 Forum 1978-1995
Sponsored by: 928 Specialists
Using 8 O2 sensor on a 928 - Todd's garage
Old 01-09-2008, 02:51 PM
Hacker-Pschorr
Guest
Posts: n/a
Originally Posted by Tom. M
Just a quick correction...Porsche started using the EGT sensors in 89. They originally used the 4 and 8 position, however in 1990 switched to the 3 and 7 due to better response from the sensors.
Whoops - considering I have a set of 89 heads at home with EGT sensors sticking out.
Originally Posted by Imo000
Why is the BPV/BOV sitting so low in the engine bay?
Because that is where he had room to put it?
Not much room up top on his engine. It's alse a pretty huge BOV.
Originally Posted by Rick Carter
ask if he can make an air/oil seperator for my 85.
It's not ready for production, still needs further testing. I'm not sure that exact design will work with the OB brake ducts.
Old 01-09-2008, 02:59 PM
AO
Supercharged
AO's Avatar
However, it's interesting to note that Porsche went to the expense of having each port machined (at least on my '91 GT), so you can swap them to any cylinder you want.
Old 01-09-2008, 04:36 PM
worf928
worf928's Avatar
Received 1,623 Likes on 1,060 Posts
Sweet Mary Mother of God.
Old 01-09-2008, 04:46 PM
Jim bailey - 928 International
Jim bailey - 928 International's Avatar
If you set your PET to Euro and click on 108-05 air injection system for cars without catalytic convertor you see how the ports were designed to be used ....
Old 01-09-2008, 06:44 PM
Vilhuer
Vilhuer's Avatar
They didn't drill holes for probes themselves to 6 holes but did make threads etc. for all 8.
Old 01-09-2008, 07:10 PM
IcemanG17
IcemanG17's Avatar
Pretty trick....Louie Ott has 8 EGT sensors on his monster....that feeds to the computer screen in the dash and shows each cylinder on a bar graph......... Of course 02 sensors gives you even more control of the engine...... The stand alone ECU's can do some pretty cool stuff
Old 01-09-2008, 08:04 PM
Hilton
Hilton's Avatar
Yep.. thats what my car has (UK cars didn't get cat's until 1990).
Makes it a bitch to undo the coolant drain plugs on the block.. those hard lines are exactly in the way, so long-handled open 13mm spanner and some small hands required!
Old 01-09-2008, 08:20 PM
Tony
Tony's Avatar
8 Inovate Widebands! That cost a purty penny! Nicely done! Got a pic of the laptop display? He must have more needles and numbers moving around on a screen than i do on a typical takeoff!
Old 01-09-2008, 08:53 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,200 Likes on 1,241 Posts
I feel like I'm having an out of body experience today.....
No - good idea. I'll snag one the next time I'm at his garage.
Old 01-09-2008, 10:17 PM
BC
BC's Avatar
He told me about this. He said the variation from midrange to top end on certain cylinders was downright.... Scary. I think I am using my words, but it was a conerning different between the short and long runners even on boost. I want to recreate this, as I will be on the edge of the stock block as well. I need more pics of how he did it at the head.
Old 01-09-2008, 10:19 PM
BC
BC's Avatar
He said there was a 1/4 inch pipe that stuck into the port just a bit.
Old 01-09-2008, 10:53 PM
90 S-4
90 S-4's Avatar
Todd doesn't intend to keep all that monitoring equipment on his car, it's just there now so he can
tune it then drive it . Once a final mapping was done there wouldn't be a need to have it on there .
That whole elabrate set up will probably be shared by those of us that have a stand alone mgt system on our car's. Todd is building a base map for the 7-ltr S.C. mtr he is building for me, it will
enable me to start my new mtr for the very first time and not have to worry about any overly lean or rich
condition's on a fresh mtr, He will send me the monitoring equpt, when he ship's the motor to me in Calif, (he doesn't know that yet)
When I'm done tuning it I'll send the octapus back to him then probably Hacker Pschorr will use it then
Todd will probably build a non-stock motor, unlike the one he has now which was only intended to
learn two thing's 1. learn as much as possible about our Autronic SM4 mgt system's & 2. see what
it takes to properly tune a 928 mtr( not make max power-now) just learn what the mtr, need's. The
big hp #'s he's been making lately are a direct result of what a proper tune can do, not his quest to
make max power -- that will come later and oh boy will he ever set some high bench mark's.
Yes, 2008 will be good for the whole 928 community...
Old 01-10-2008, 01:38 AM
hacker-pschorr
Step 1 - find a way to adapt this setup to a 16V motor since those heads do not have the EGT ports.
Todd already has it in his head how to do this. Just need to extract that data
Old 01-10-2008, 04:19 AM
Bill Ball
Under the Lift
Bill Ball's Avatar
Very cool! He told me about this, but I had a hard time imagining it. Thanks.
When you saw this pic, did you go "Holy Christ!", like I did?
Old 01-10-2008, 09:57 AM
fabric
fabric's Avatar
My reaction was somewhere between that and
Originally Posted by worf928
Sweet Mary Mother of God!
Quick Reply: Using 8 O2 sensor on a 928 - Todd's garage
