Whats the easiest way to detect LSD?
#46
Sounds like clutch chatter. What are you using for gear oil ? There are additives to lubricate the friction discs (clutches). Myself and others use synthetic gear oil and have no chatter.
#47
Shameful Thread Killer
The reason you don't have chatter with syn fluid is that the LSD clutches have no traction to grab on. You've solved one problem but exacerbated another, as you've over-lubricated the clutch pack with syn fluid. I have LSD on several of my other cars, and you may want to go back to dino fluid, or use an LSD additive as GM does on their Corvettes with LSD.
This can also create problems with the EP additives. Syn lube is almost always better in any application, but there are some drawbacks in specific applications, the LSD is one of those applications.
#48
Chronic Tool Dropper
Redline makes a syn oil specifcally for limited slip applications (-NS is for the non-limited slip apps IIRC) . As Doc mentions, you can use a commonly-available friction modifier in conventional lubricant to 'tune' the friction in the clutches. The Devek crew used to recommend a dino oil (Swepco) in limited-slip applications I think, definitely in the manual gearboxes.
You can 'tune' the clutch pack friction with new disks and shims to get pretty much any amount of lockup you want. As I mentioned earlier, lots of friction/lockup is not always a good thing. In fact, it's only a good thing when you have uneven traction when accelerating, and generally only in a straight line if the clutch friction is cranked up. If I was driving in snow it would be a slow-speed blessing when accelerating, and a curse when cornering, for instance. Think of how a 4-WD true car drives on hard pavement. A tight LS unit gives the same symptoms times half, with only two wheels crabbing as they try to turn at the same speed going around corners.
#49
The topic interests me as i am about to swap a LSD unit bought from 928INT into my 87 euro. Can someone give me a heads up on setting the LSD.....how do you make adjustments to the amount of slip and what is an optimum number.....i do DE's, so handling is important....i have the workshop manuals but haven't found any info on mechanical LSD......any help would be appreciated as the diff comes out on Thursday.
John
John
