Whats the easiest way to detect LSD?
on your 928 that is, duh, lol. really though if your were to go and look at a car how will you know> What is the best way?
Does it leave 2 black marks when you drop the clutch?
If you mean without driving it the psd unit is behind the drivers side back tire, at least in S4 and later Sharks.
Oh yea, and cookies are much more fun with LSD.
Team Owner
to tell if you have a posi, both wheels off the ground , they will turn in the same direction when you turn one side.
In a open diff, one side will spin opposite of the turned wheel.
The PSD modulator is behind the left rear wheelwell block off plate.
oh no I'm in the wrong forum... but I'll chime in because I think I know.
Because you said that you laid two marks down that were even, (one didn't stop or start at another time in the burnout) I am almost completely sure you have a limited slip diff(lsd). I don't even know if 928's got a positraction.
You might be able to reach far enough using a digital camera in Macro mode to do it without jacking up the car?
burn rubber by dropping the clutch on some smooth pavement. (as someone suggested. ) thats the easy way! two black marks equal length is limited slip.
mk
mk
The other option is to look for option code 220, although no guarantee something hasn't been changed.
Originally Posted by N/a 944
... I am almost completely sure you have a limited slip diff(lsd). I don't even know if 928's got a positraction.
http://en.wikipedia.org/wiki/Limited...#Factory_Names
Positraction is just Chevy's name for LSD - it's just the one that stuck, probably cause the other names are stupid. According to same page, Ferdinand Porsche is responsible for the LSD.
Administrator - "Tyson"
Yes – same thing.
Positraction is GMs trade name, TrakLok is Dana's and Traction Lock is Ford's – all of them are the same thing: Limited Slip Differential or LSD.
Supercharged
LSD is a mechanical Limited Slip Differential.
PSD offered from 90(?) - 95 is an electronically modulated LSD that is progressive from 0% to 100% in 10% increments IIRC. The PSD uses wheel speed sensors and accelerometers to detect if one wheel should be spinning faster than the other and modulates the PSD accordingly until the two come in line with a predetermined set of parameters. Some have remarked that they don't like the PSD for racing (it's heavy), but for street driving it's quite nice IMO.
