Heater Valve Modification
#31
Bob, that 2nd valve sounds like a great idea. I have a vacuum switch that I was planning to install, basically a winter/summer switch where in one position it is a pass-through, in the other position it connects the heater valve to the vac reservoir. Your suggestion seems like a more elegant solution. Have you identified a part that will do the trick?
#32
Chronic Tool Dropper
#33
Stopped by the local Advanced Auto Parts store and gave the clerk the number to cross-reference. They can't. Their system only knows applications. No descriptions either. System is built to be fool-proof I'm sure. And it is fool-proof. May need to just bite the bullet and get a couple from Rock or one of the other online vendors.
Meanwhile, for those playing along at home, the valve is originally used on the legendary Escort GT and GL models, the Mercury Lynx and Topaz, and the Ford Tempo, all in years 1984 and 1985. It's a pretty narrow window. If you go shopping locally, the key is that the valve needs to be closed when no vacuum is applied to the actuator.
#34
dr bob,
On my truck, the vacuum actuated heater valve also opens when you shut off the engine. But no hot air blast when you restart on a warm engine.
The difference is, Ford installed a cold water traps in the roomy engine bay. The heater core inlet and outlet pipes at the fire wall are 6 inches lower than the top of the cold water traps. Here's what they look like....
![](http://img37.imageshack.us/img37/1584/heatervalve001a.jpg)
I found a 3-way solenoid valve on eBay for about $16 with shipping. I posted a photo of it at the other other thread here: https://rennlist.com/forums/928-foru...uration-4.html
