928S4 head CCs
This is what I was trying to follow:
[quote]
V1+V2+V3+V4+V5
______________
V2+V3+V4+V5
Where V1 is the swept volume
V2 is the piston to deck
V3 is the volume of the head gasket
V4 is the combustion chamber
V5 is the top of the piston
<hr></blockquote>
Any ideas?
Based on
CR= (Swept+unswept)/ Unswept
You can derive
Unswept = swept/(Cr-1)
How the Unswept is made up is another matter, and which parts you can do much to change is problematic. If you know the bore and compressed gasket thickness you can calculate volume there. If you know area of chamber face at gasket, you can work out effect of skimming head.
HTH
jp
So maybe 50cc in the head?
Any opinions?
You will need -
Vol of chamber
Vol of concave piston crown (Add to above), or volume piston crown ABOVE flat (subtract from above) - zero if piston flat
VOlume of gasket thickness
Swept volume of cylinder
Assumes piston crown stops exactly at block deck level - if lower, add volume below deck to chamber volume, then you can calculate CR. YES you need piston height to find out where crown reaches in cylinder.
jp
jp
I have not purchased pistons yet. That is kind of a problem, as I need to calulate what I will need in the piston design from what compression ratio I get with a 95.25 crank stroke, possible 5.7inch chevy rods, and the basic head chamber. If I can get the Deck Height and CC of the head chamber, I can have good numbers to work from with the piston makers.
