928 Forum 1978-1995
Sponsored by: 928 Specialists
Injector removal from wiring
Old 11-30-2007, 06:24 PM
  #31
StratfordShark
StratfordShark's Avatar
Originally Posted by Mako 928
Don't know what other people are doing but on MY '85 I....
1.Disconect the fuel rail from the fuel lines.
2.Remove the small metal clip from the injector plug.
3.Remove the plug from the injector.
4.Remove the rail W/ the injectors and put it on the work bench.
5.Remove the retaining clip from the injector/rail.
6.Remove the injector from the rail.
I will be doing this soon on my S4.
Have read all the intake removal guides and am unclear on just point 1 above i.e. disconnecting the fuel rail from the fuel lines.
Can you undo the line directly from the rail or do you always disconnect at the fuel pressure regulator (at the rear) and damper (at the front), leaving short lengths of hose attached to the rail.
In other words is there a correct choice between disconencting at the regulator/damper v disconnecting at the rail itself?
Old 11-30-2007, 11:21 PM
  #32
worf928
worf928's Avatar
Received 1,603 Likes on 1,047 Posts
Originally Posted by bernard farquart
I found it fairly easy to pull the whole rail and injector assembly out as one piece, then you can work on the bench from there.
That method will work well in my experience, if, and only if, the injectors have been out of the car in the last few years. Injectors that have been sitting in their little intake holes since they were install by Klaus at the factory are harder to get out. The top o-ring will give up first regardless of the clip being in place or not. Also, you risk munging-up the rail if you have to yank too hard to get the injectors out.
Last year I pulled the injectors out of an '85. The o-rings were so bonded to the intake runners that the pintle caps shattered before the o-rings would move. I had to cut the o-rings out of the runners.
Old 11-30-2007, 11:30 PM
  #33
worf928
worf928's Avatar
Disconnect the rails at the coupling closest to the rails: Disconnect the left-side (driver on LHD) at the dampeners. Disconnect the right rail at the regulator and the short front fuel hose. Other methods, such as trying to remove the rails, regulator, and dampeners as a single unit will put a lot of stress on the various fuel lines. Leave all the other fuel lines alone unless you plan to replace them right now. (Given the age of the lines, once you disconnect the short front hose check its condition carefully. If a divot has been worn out of the the line by the oil filler neck, or if the hose is turning in the fitting, or if there are visible cracks when you slightly flex it then replace it. Check all the other fuel lines for cracks too. If there's any doubt replace them. Fuel fires bad.
If I'm not replacing the front line, I loosen the front fuel line at the right rail then pull the rail, then disconnect the line. Installation is the reverse. Thread the line onto the rail just enough to get it started, install the rail (with injectors and clips already in, and o-rings lubed) then tighten the rail nuts and the line. This places the least bending stress on the front fuel line and is a bit easier too.
Old 11-30-2007, 11:37 PM
  #34
the flyin' scotsman
the flyin' scotsman's Avatar
I should mention that I replaced all fuel lines earlier this year as a matter of maintenace........Roger has a great kit.
Old 12-01-2007, 01:37 AM
  #35
bernard farquart
bernard farquart's Avatar
Location: Seattle, where everyone is above average, and the women are all beautiful
[QUOTE=worf928;4834788]That method will work well in my experience, if, and only if, the injectors have been out of the car in the last few years. Injectors that have been sitting in their little intake holes since they were install by Klaus at the factory are harder to get out. The top o-ring will give up first regardless of the clip being in place or not. Also, you risk munging-up the rail if you have to yank too hard to get the injectors out.
Guess I was just lucky then. mine came out fairly easy, had to pick some of the lower o-rings out of the intake, I did crack a couple of the pintle covers, but I was replacing them, so I was unconcerned with that detail.
Quick Reply: Injector removal from wiring
