928 Forum 1978-1995
Sponsored by: 928 Specialists
Brake pad replacement help
Old Nov 16, 2007 | 11:09 PM
jpitman2's Avatar
jpitman2
When you are pushing the piston back to make room for new thicker pads, watch for the fluid backing up into the reservoir - keep a rag there to mop up spillage, or suck some out somehow. I havent had to bleed brakes for pad changes in the past. From looking at WSM, floating frame has pins as described above, floating caliper requires a couple of pins to be unscrewed with a 7mm socket from the inside face of the caliper. Niether looks difficult though. I think my 83 is floating caliper, yours me be the other style.
jp 83 Euro S AT 51k
Old Nov 16, 2007 | 11:32 PM
85fortheDrive's Avatar
85fortheDrive
Artist Formerly Known As 84totheFloor
Originally Posted by CaseyH
I'm looking at the WSM and I'm slightly confused. Does my '81 have floating frame caliper disc brakes or floating caliper disk brakes? I think I have floating frame, but I want to make sure.
The WSM is confusing. Can you provide a pic of your brake calipers? If they're the same as mine, then I can help you through the project. BTW, be sure to keep a milk crate or similar sized support nearby. When the caliper housings come off, they should not be allowed to just dangle.
To avoid pushing too much fluid back through the lines when you force the calipers open, push the brake pedal after each set of pads is installed. This pushes brake fluid back toward the calipers, away from the reservoir.
I know someone who didn't do this and had a messy cleanup.
Old Nov 17, 2007 | 05:55 PM
JHowell37's Avatar
JHowell37
Your car has floating frame caliper discs. The pad replacement procedure is on page 46-2 through 46-4.
