In case anyone is interested heres a pic of the welding on my head
if you do the claying of the piston valve reliefs with a mockup of the engine, i bet the valves dont even nick the silly puddy. the main concern with the shaving of the heads is how i effects compression ratios.
1mm shaving would raise the compression ratio near 1 point (thats near 7ccs)
all you really need to do, is take a box end wrench, and lever down the valves and measure how far they go down before they hit the pistons. (clay is to see where they hit too) if that number is .3" or greater, you have nothing to worry about .
mk
mk
this is what im referring to. slow motion 1000fps video of what happens in teh combustion chamber.
http://gizmodo.com/gadgets/fourstrok...?autoplay=true
Under the Lift
The Lady's Man
