HVAC blower squeling
#46
I finally pulled the blower motor again. I disassembled it to learn the noise is not coming from a bad or dry bearing - there are no bearings. Both ends of the rotor use bushings and they are hardened. I relubed them and assembled. The motor now sounds fine but only time will tell.
I also made a hole in the top through the plastic so that I can add oil to the top bushing if needed.
1986 5 speed
1986 5 speed
#47
This morning I completely removed the blower and did not remove the hood, What I did was remove the recirculation flap and droped the blower into the passenger side compartment. Does anyone know if there is a part number for the recirculation flap gasket, mine is mostly missing
Dan
'91 928GT S/C
