my 1st porche project
#47
Shameful Thread Killer
No, it's not. You probably have a RMB(rear muff bypass). Generally the cars aren't loud unless their are driven quite hard. Once you are under there to get the oil changed, get that clutch slave done too. Remember, BY THE BOOK including the bleed procedure. If you didn't order a clutch master cyl green hose, go back and order one, or use surgical tubing(NOT plastic line, surgical) from the master to the reservoir. Save you some grief later in life.
#49
Man of many SIGs
Bleeding the slave cyl. can be a major PITA without a power bleeder. Try to borow one locally or you can buy one. They are nice to have but you wont use it that often.
Get the car running so you can drive it. Once it puts a smile on your face you will feel better about having to spend money on it.
There was a guy who used to post here. You kinda remind me of him. His name is Danglerb. He has a quote in his sig that says " TLC means truck loads of cash". Did the previous owner tell you that this car just needed a little TLC?
#50
#51
[QUOTE. Did the previous owner tell you that this car just needed a little TLC?
[/QUOTE]
nah he just told me what needed to be done or what his mechanic told him that needed to be replaced which was the slave cylinder, thermostat, and belts and hoses and sparkplugs and wires
#52
#53
ok so another weird thing happen'd today i turned the car off to let it cool down and about an hour later i turn it back on and it would idle funny for a couple mins like it would rev then almost stall then rev then almost stall it was really weird unfortunatly the tach doesnt work or id list the rpms that it was doing this any suggestions?
#58
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Matt
#60
[img=http://img517.imageshack.us/img517/8665/scan000123232mb9.th.png]
heres what it looks like i put 3m tape on the windows because i was going to repaint it as my first idea but took it off since i decided to get it up and running first
